FixYa.com
Tags:
FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
What about animation on DVD? Doesn't it compress...
By kioner - usenet poster
What about animation on DVD? Doesn't it compress poorly?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 76%, 111 votes
no DVD 's are especially designed just for this and work very well with most any images or sounds. Otherwise movies would not be sold on DVD's.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 29, 2007
Not Rated (0)
ffarkle
Rank:Apprentice Apprentice
Rating: 60%, 3 votes
Compression does not affect or censure the content of the video. Compression rate effects will be noticed on any video regardless on whether the video is comprised of animation or other content.
Solution #3
posted on Aug 08, 2005
Thanks for Trying (70)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
Some people claim that animation, especially hand-drawn cell animation such as cartoons and anime, does not compress well with MPEG-2 or even ends up larger than the original. Other people claim that animation is simple so it compresses better. Neither is true.
Supposedly the "jitter" between frames caused by differences in the drawings or in their alignment causes problems. An animation expert at Disney pointed out that this doesn't happen with modern animation techniques. And even if it did, the motion estimation feature of MPEG-2 would compensate for it.
Because of the way MPEG-2 breaks a picture into blocks and transforms them into frequency information it can have a problem with the sharp edges common in animation. This loss of high-frequency information can show up as "ringing" or blurry spots along edges (called the Gibbs effect). However, at the data rates commonly used for DVD this problem does not usually occur.
This Problem Also Relates To: Audiovox D1708 Portable DVD Player with Screen Audiovox VM9311TS Audiovox 15-Inch 4:3 TFT LCD TV with DVD Player FPE1505DV Memorex MVDP1072 Portable DVD Player with Screen Memorex MVD2028 DVD Player Memorex MVD4543A Panasonic DMRES15 DVD Recorder
Can you Help with these DVD Players problems?
Burned dvd won't play in dvd...
I haven't used the... Answer This...
dvd/cd-rw drive
my dvd/cd-rw drive recognize... Answer This...
DVD- RW drive
The DVD-RW drive of my PC is... Answer This...
how to put plugs in a dvd
i am having a panasonic vcr ..... Answer This...
ted
sex reletive Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
