Question about Intel Motherboard
How insall new bios
System cant boot ,tell me how install or flash new fresh bios
  • David
    David May 11, 2010
    How do you mean cannot boot. this could be a lot of things more details please
    Problem Solver:
  • 17 Answers
Try taking your CMOS battery out first, its a small silver circle in your motherboard. just take it out for like 10 seconds and then put it back and that will reset your cmos/bios. if you insist on flashing go to your motherboard manufacturers website and look for the download.
Posted on Dec 19, 2008
My server cant boot after a fresh intall
Reshuffling disks will disturb the Logical drive .Recreate RAID Install OS , Set the Boot controller order in system bios Pressing F10key
Jul 25, 2012 | HP Compaq ProLiant ML350 G3 Server
Tell me the bios password for fujitsu 7220NU5/B
You will not be able to clear the bios password.
You will need to generate an MSDOS boot Floppy Disk there are a number of sites online that can show you how to do this.
This disk should also have FDISK on it.
Insert the disk and start the PC, it should boot up from the floppy. Now run FDISK and clear all partitions on the Hard drive. DO NOT make new partitions.
Remove the floppy disk. Insert the boot CDROM and restart the PC.
as there is now no boot partion on the hard drive the system should boot from the third device the CDRom.
Continue to re- install the system as normal
Apr 14, 2012 | Fujitsu LifeBook Computers & Internet
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
New sata hard drive i installed keeps saying ntl not found checked bios ok cant start up to format drive or insall opperating system any idea?
Hi mikecoombe,
The easiest way to put in a new drive is to boot to the old drive as a master then put the new drive in as a slave. Make sure that if your using all sata drives, that you specify which drive to boot to in your bios. Then Format from your OS, and load away.
Good Luck
Mark
Sep 17, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I want convert ntfs to fat 32
the convertion from ntfs to fat32 will result in loss of all data in the drive (all data from desktop,my documents, installed programmes.......). You can do this using your windows disc . Just set the primary boot device to be cd-rom in the bios,boot with windows cd in drive,then the installation will guide you to the insallation of a fresh copy of windows (there you can select the required file system).it is recomended to continue with ntfs
Feb 28, 2009 | Microsoft MS Windows XP Professional SP2
NO BOOT OPTIONS FROM CD
simple if you need to format your system then insert the windows xp cd in a normal mode and go to installation and it will ask for the an upgrade or fresh installation select fresh installation no need to enter bios this reboots your system via cd and let youformat your machine.
Feb 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
How install new bios
After updated your bios, did you check the boot sequence?
it might have been changed. Go in to the bios again and check so the boot setting is pointed that your pc starts from your HDD.
If you trying to reinstall the OS you should change tye boot to start from you cd-drive.
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 12, 2008 | Intel Motherboard
Insalling windows xp
As the pc is booting press F2 or Del (dependant on bios) and enter bios set up.
Choose to make your cdrom as first boot device, save settings and exit bios.
Insert cd drive before the boot up starts and there will bea screen prompt to "press enter to boot from cd", press enter and then the cdrom will go to the next step, asking press 'R' to repair or press 'Enter' to format and install windows, choose repair if you have documents you need on your pc.
The system will then go through a full repair installation, when complete your system will be repaired and everything should be as before with nothing lost.
You may have a faulty hard drive so if you cannot get windows to repair it will tell you theres no drive found.
Sep 10, 2008 | Computers & Internet
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
