Question about SanDisk Sansa E280 MP3 Player
Driver software for sansa e 280
My system does not recognise my sansa e 280 player i need driver software , it says that windows does not recognise the device attached to the computer.
  • 1 more comment
  • demay26 Dec 17, 2008
    I have the same problem and it's very frustrating b/c when I go to download the software, it says my device has to be recognized by Windows, but that's the problem to begin with.
  • jcliston Jan 08, 2009
    cant find device
  • Anonymous Jan 26, 2009
    my system does not recognize my sansa 8gb mp3 player
  • 8,596 Answers
Make sure the hold/lock is not engaged.
If any of you have Windows Vista, you have to go to Sandisk's website to get the compatible software.
-Tha Mp3 Doctor
Posted on Jan 18, 2009
SOURCE:
It wont read in windows media player but i unplug it does but every time i plug it in it just makes it slow
If you recently updated the software online it may have changed the USB setting on your sansa. Go into settings - USB mode and select MPT. Windows media player should then recognise your sansa. Hope this helps.
Jun 02, 2011 | SanDisk Sansa Clip MP3 Player
Usb is not recognised
you should turn the player on after connecting it to the computer.then it will be detected.previously it was not detected because you didn't turn it on.this should work
Jun 03, 2009 | SanDisk Sansa E280 MP3 Player
SANSA 4GB PLAYER
Have you tried updating your Windows Media Player to number 11? this has the drivers for SansaClip. Go to windows website, download WMP 11 and then plug in Sansa and uyour computer should recognise it. Good luck.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
just go to piratebay.org and search for it and download it.
Dec 13, 2008 | SanDisk Sansa E280 MP3 Player
Sansa clip installation
What you need to do is update your Windows Media Player. I believe it has to be WMP10 and higher. Let me know if that works. Oh and you also need at least Windows XP Service Pack 2. so update your windows software
Nov 08, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250R rapsody mp3 player
Get software from Sandisk's website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 16, 2008 | SanDisk Sansa e250 MP3 Player
Not enough space?
What i would recommend you to do is to format the player using the player itself and if that doesnt solve the problem i would recommend you to use windows media player to format your device...to format your player using windows media player go under the sync tab..assuming that you are running windows media player 11..your device should be listed there on the right side...just right click on it and hit format and that should solve the problem..DO NOT USE MY COMPUTER TO FORMAT THE PLAYER BECAUSE IT WILL DELETE EVERYTHING ON THE PLAYER INCLUDING THE FIRMWARE...let me know if that doesnt solve the problem...
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Unit not recognised by my computer or any other, and memory issues on another unit.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
174 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
