Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Camera will not go on
I have a canon sd300 it is about a year old. I took a picture with it, turned off the camera and tried turning it on about 30 mins later and it would not go on. I thought perhaps the battery was dead so I recharged it but the camera is still not going on. Please help !!
    Novelist:
  • 107 Answers
If you push the power button and do not see any signs of life at all, it is most likely a blown fuse. In this model disassembly is required to replace the fuse, and it is soldered onto the main power board. If there are signs of life, but the camera does not function there are other explanations. Jammed lenses are the most common cause of power-on failure. Check with your manufacturer for recalls and warranty service information. Failing that you can find a repair provider online. David Millier Advance Camera Repair
Posted on Mar 13, 2007
SOURCE:
My canon sd300 will not turn on
I had the same problem, and finally I took it to a camera repair shop and they said it was time to get a new one.
Dec 17, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Focuses but never takes picture
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON).
However, as mentioned it may be only a break in the safety circuit. Canon usually some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, try moving and replacing any missing screws with one of the others that are still there.
May 26, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon sd300 cant see pictures taken
This may sound silly, but did you check the shutter on the end of the lens when the camera is on to make sure that the shutter is open? Sometimes some dirt or sand can get into the lens barrel and make the shutter get stuck in the closed position. If this happens, gently open the shutter with a a toothpick or something (NOT your finger because of the oils and NOT something that will scratch the lens).
If the shutter is open and the pictures turn out black both on the camera's LCD and on the computer once you download them, then I'm guessing something happened to your CCD, which is the tiny electronic chip that records the light coming through the lens. Either something inside the camera has fallen in front of the CCD and is blocking the light (unlikely) or the CCD chip has died. If that's the case, I hate to say it but buying a new camera would be more cost effective (and probably cheaper) than getting it fixed.
Apr 10, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
E 18 problem
Your first problem sounds like a defective CCD imager. If your camera was an S300 Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Unfortunately, you mention that your camera is an SD300. That model camera is not currently on the recall list. But you might want to call Canon anyways. You might get lucky as the problem sure sounds familiar to the recall (excuse me, advisory hehehe).
As for the SD500 with the E18 error, try http://www.e18error.com/repair.html
Nov 13, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon sd300 lens noise
Defective mechanism, You need professional service to fix it, or better give it back asap,  digital camera lasts only for three years working at its best form, I suggest you buy a brand new one and sell it after two years of use. [:0)
Oct 29, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory Card is locked up?
Hi Phatback, There should be a switch on the card, move it in the opposite direction. If this does not work, format it in your PC. Please let me know if this works. Best regards, nightdiver
May 30, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
