Question about Lexmark P4350 All-In-One InkJet Printer
Message on screen printer in use when it is not....
Pressed select button and added paper as requested on screen still nothing happens seems to be stuck, it has happened once before and weeks later started itself off all of a sudden. Thanks. at the time I had printed off information of a normal web site.
  • caroleelm Dec 20, 2008
    Thanks Kornho, your advice has worked.
    My printer works well.
    All good wishes
    Carole.
  • 781 Answers
I would do the following:
1. first try to restart the printer spooling service (go in to the services applet and look for print spooler and restart the service. then test.
2. I would uninstall the printer and driver (disconnect printer and delete the printer from Printers) then reinstall.
Hope that helps
Posted on Dec 20, 2008
HP Photosmart PremiumC 309g-m started a day ago will not print anything even test page. Message says load paper into photo tray. Nothing obvious seems to work, shutting down printer and restarting,...
Unplug the power from the printer.
Press the # key and the 6 at the same time and hold them down
connect the power while continuing to hold down these keys
wait for a message about a semi-nvm reset or something like that to appear on the screen, and then release the buttons. If the unit shuts down while you are pressing the buttons, release them, and press power just long enough to turn the unit on.
If the printer does not react normally after this, post a reply here.
Feb 24, 2011 | HP Photosmart Premium C309A All-In-One...
I wantto print from tray 2. but it always print on tray 1
When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an "autoselect" process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
Press the "Check" button, scroll down to "Paper Handling", press the Check button again, scroll down to Tray 2 Type and press the check button again. Select the type of paper you have in that cassette and confirm by pressing the check button.
Nov 16, 2010 | HP LaserJet 4700N Printer
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
SAYS GOT PAPER JAM
With the message should say where is the paper jam. If you can not find this information you can try:
  1. Pull the paper tray, specified on the Display Screen, completely out of the printer.
  2. Remove any jammed paper from inside the tray slots. Make sure there are no pieces of paper jammed in the tray slots.
  3. Make sure to use paper within specifications and that the paper is loaded correctly in the tray. See the Related Items below for additional information.
    NOTE: When the paper edge guides are correctly adjusted, there may be a small space between the paper and the guides.
  4. Adjust the length and width tray guides:
    1. Length guides: Press the sides of the guide, and then slide the guide until the arrow on the guide point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guide will click into place.
    2. Width guides: Slide the width guides until the arrows on the guides point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guides click into place.
  5. Remove the top sheet of paper from the tray.
  6. Re-install the paper tray in the printer, and make sure it is completely closed.
  7. Make sure the pick truck and ****** roller set is installed and seated properly. Clean or replace both of these roller mechanisms, if necessary. See the Related Items below.
If none of this clean the JAM message you might want to power OFF/ON the device.
If that also does not clear the message you can go a bit deeper and reset the device. THIS WILL CLEAR ALL YOUR SETTINGS, might inclusive clean TCP/IP settings. So I advise you to print configuration report first then.
If you wish to do this here are the steps. NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAM to their factory default values. The print count and the Adobe firmware serial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM. See the Related Items below for additional information.
  1. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  2. Press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Aug 27, 2010 | Xerox Phaser 8560DN Laser Printer
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Dec 09, 2009 | HP LaserJet 4200 Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP 2420dn out of paper
To perform a cold reset
1. Turn the printer off.
2. Hold down the SELECT ( ) button, and then turn the printer on. Continue holding down
the SELECT ( ) button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW ( ) button or the DOWN ARROW ( ) button until COLD RESET is highlighted.
4. Press the SELECT ( ) button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values.
ENWW Printer resets and power-on modes 163
Mar 14, 2008 | HP LaserJet 2420 Printer
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
