Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Getting to the belt
How in the heck does the bottom come off so you can get to the belt? I only see two screws and I unscrewed them and it still isn't coming off. I've looked in the manual and it doesn't even say that it has a belt, but it has to be the problem because I have tried everything else.
  • popa fix it Mar 30, 2008
    I have removed the turbine gear box, but during reassembly an o-ring fell out and I don't know where it belongs
There is no belt. if your brushes don't spin it may be your turbine gear assembly. my suggestion (if you only see 2 screws) you better take it to a service center. there are 7 screws holding the hood on.
Posted on May 08, 2007
Vacuum cleaner mo# 82G7-1 how to change belt
Adding the MAKE is always a help in such questions. See the link for your Bex Bissell.
vacuum cleaner 82G7 1 how to change belt Google Search
Mar 04, 2018 | Vacuums
Shark navigator uv300 roller stops while vacuuming filters are clean and not clogged up
The belt that turns the rotating brush is loose. Make sure it is on correctly or replace with a (new) tighter belt. This will require you to unscrew a few screws on the bottom & remove the cover. Then remove the roller.
Nov 06, 2013 | Vacuums
I need to know how to change the belt on a fantom xt
Turn it upside down.On the bottom where the brush is are 4 screws.Unscrew those 4 screws.Remove the plate.Now you can see the belt.There may be a second plate covering part of the belt,if so remove it too.The belt fits around the brush in a groove the same width as the belt.The other end of the belt fits on a small wheel about half way back from the brush.Put the plate back on and you are done.
May 14, 2011 | Vacuums
Belt is broken. Not sure how to replace
1. Get a long screw driver (probably phillips head) a strip of tape.
2. Look around underneath your vac for screws... look carefully because sometimes they are sneaky and hidden in weird areas like under the wheels, etc.
3. Take screws out stick them in order on tape turned upwards. (remember how you took them out.)
4. Gently remove the bottom cover.
5. Clean and remove debris, hair, dust bunnies, rocks... whatever.
6. Determine where the belt goes, disengage the beater bar on that side (may need to unscrew something) Belt on beater bar gears. Other end of belt on motor end... then stretch belt with beater bar until it fits back in it's place and replace any screws, etc.
7. Make sure the belt is seated properly.
8. replace cover, screws... test.**
** sometimes belts require that you put a twist in them so it can transition from the motor's direction to the beater bar's direction... if you twist the wrong way... the beater bar will spit dirt out the front of the vac.. (it's bulldozing it) In that case remove cover and twist the belt the other way.
Good luck.
Mar 12, 2011 | Vacuums
How do I change the belt on a Bissell Powerforce model 3522-1?
this is how you do it Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Feb 16, 2011 | Bissell 3522 PowerForce Bagged Upright...
How to replace band
Make sure vacuum is unplugged. Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Oct 03, 2010 | Bissell 3522 PowerForce Bagged Upright...
HOW DO i CHANGE THE BELT ON MY EUREKa powerline
turn the vaccum upside down and unscrew the screws in the bottom, pop that cover off and you should be able to remove the wheel assymblie. take the old belt out,slide knew one over the shaft and replace the cover and screws
Mar 25, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
Hoover U5163-900
Just discovered this same problem and the belt was a mess when we pulled it out. Now have to try to find a replacement and see if we can get it back on. To find it though just remove the 4 screws that hold the red cover on 2 on the bottom and then two on the top. You will then see two screws near the front holding the black casing for the roller. Just unscrew those and the belt will be hiding under there. Good luck.
Oct 13, 2008 | Hoover U5163-900 Upright Vacuum
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
50 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
