Dear sir good afternon , i have a problem with my computer,that just now i change a power supply.bcose the old one fused. than i pluged well,as i start my PC i heard a beep. & monitor doesn't display.
Thanks for your support.
i just change RAM & placed it to the near slot & after that i restart the computer,
now it is working smoothly,,.
tnx & regards
Posted on Dec 14, 2008
I plug out my lexsor tv and when pluged back in it wont not come back on. I change fuse in plug also still nothing
Hi Katie,
Please have the power cord checked. Sometimes it goes bad while pulling out from wall socket. If that is ok then it is the power supply board which is not working.
Good luck.
May 13, 2015 | Televison & Video
No power fuse blew
it means you have shorted regulator transistor on power supply..
It is usually fit in heat sink..
Try to replace it and the fuse again also check any fusible resistor near that transistor..
Feb 23, 2012 | SNK Magnavox 32MF338B27 32 in. LCD TV
Sir why a power supply become fuses and blast when computer vga and power cable is put in the cpu?
You have a serious electrical short in your computer which causes the fuse to blow.
Depending upon how old your computer is, it may not be worth repairing and in this case I suggest you put your money towards a new computer or laptop.
Aug 31, 2011 | Computers & Internet
Computer not working. checked the power sup & its good. I see a light blinking in the mother board (next to the power connecter. How can I fix it?
Hmmm... if it won't turn on make sure the power button is pluged into the motherboard correctly.. if it is already and your computer still won't power up try switching out the power supply because sometimes they only go out partially, i had that happen with my old computer, the pwer supply only powered half the motherboard and unfortunantly it powered the cpu but none of the fans and completely fried my processor. Hope this helps, Daniel
Oct 25, 2010 | Computers & Internet
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
On pluging on the main AC pluf, there is not
do you have the cord plugged into the computer? is there a switch on the back near the power supply? if so, is it on? is the large connector from the power supply tightly latched to the mother board? (unplug the computer before you check this!) any fans running? plug a lamp into the outlet and see if it has power! could be a popped breaker, or blown fuse.if you feel confident of your skill, remove the power supply, open it up and see if it has a fuse that may be blown. if so, replace it with a fuse of the same type (size & amperage). if the fuse was blown, and you re-install the power supply and it blows again, then you have a problem (probably) with the power supply, and if cost effective, it needs replacing! get a compatible power supply with a higher power rating, if you can! more power for your peripherals!
good luck!
Sep 28, 2009 | Compaq Evo D510 Minitower (Open Box)...
Will not come on /nothing happens
you have a power supply problem, i will check the power supply first. maybe it is only a fuse.
May 19, 2009 | Sanyo DP32746 32 in. LCD Television
Daewoo cp185
Power supply may be faulty.
Initially check fuse in power line input.may be burned.
Jan 23, 2008 | Televison & Video
Wrongly started and fand is not working. now what to do.
on the fan nameplate does it state 220 volts or 110 volts? there are no fuses inside. this is a good place to begin...
Aug 18, 2007 | Brookstone MiniMax Tower Fan
Loss of power
I have a similar scanner, scanjet 5470c which is using the same power supply as 5400c and 5490c
2 weeks ago the scanner stopped working, yesterday i checked the scanner and found out that there was no power (12V)
the power module (black box) going into the 220V is a plastic box without service possibility. I took a screwdriver and a hammer to open the box. Inside the box i found a lot of electronics and yes a Fuse aswell. I did not have spare fuses, so like all bad boys i replaced the fuse with a wire, and guess what? .. yep I blew several main fuses in the house and now have a burned-out power supply.
the power module is still available at the HP Parts Store the part number is C8517-84201 i see a list price of 23 EUR
Before a buy a new power module I will first test the scanner with a spare 12VDC and see if he still works.
I will come back and tell you if it works...
Feb 17, 2007 | HP Scanjet 5400c Flatbed Scanner
Computers & Internet Logo
David Payne
David Payne
