Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
NO BLACK IN PRINT OUT
Pls help me with my printer, whenever i print the result is no black in my print out but the colour print out is ok and also when i do test print the result or the print out has no black but 3 colors are ok, magenta, cyan and yellow. pls help me. i dont know if the problem is with the cartridge or with the printer's mechanical. pls helppppppp.
thnks and pls reply soon
    Scholar:
  • 78 Answers
Check if your black cartridge is full. If it is you can do a prent head clean through the "ink management" button on your console. Be sure to only clean the black. It will prompt you do print a nozzle check, print this out. It will show you what heads are working. If after a couple of head cleans, there is still nothing showing on the test page, leave the printer on over night and try again tomorrow. there may be an air block in the tubes and the printhead clean will have moved the lock and it will clear by itself.
Gremlin11
Posted on Dec 13, 2008
Remove ur black catrige clean the contact surface
and replace properly and give a calibration ur problem will be solved
Hi. I have a Canon MP560. How do I print in only black and white, using only the black ink? Grayscale mixes in coloured ink. The printer will not print at all unless there is colour ink in it. I only print...
Hi
Follow these steps;
- Open the document you want to print - Go to 'file' - 'Print' - click 'properties' in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select 'Black Only' - click 'OK' - again click 'OK' - now you can print only using the black ink in the printer.
Hope this helps, Please rate if this solution was helpful. thanks!
Aug 27, 2011 | Canon MP560 All-In-One InkJet Printer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Xerox DocuColor 4CP printer will not print colour. It will print black fine though. Have defaulted printer and printed colour page, still no colour, just black.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=DC4CP&Xlang=en_US&Xcntry=USA
According to this site, Windows 7 drivers are available for the Xerox Docucolor 4CP printer.
What operating system are you using?
Also, is it possible that your color toner has been depleted?
Jul 18, 2010 | Xerox Office Equipment & Supplies
My Epson DX6050 has run out of colour ink but i just want to print black only. how can i print my text doc in black?
Sorry, any inkjet printer will not support without colour caterige, so please fill colour then take printout in black . If my sugession is helpful pls rate this answer
Feb 26, 2010 | Epson Stylus DX6050 All-In-One InkJet...
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus DX 7450 doesn't print black
Hello, This can be FIXED. I'm not trying to be helpful. I'm here to FIX your problem.
You want to make changes to the printer settings to once again print in Black and White or Grayscale mode by going to Start Menu, Control Panel, Printers. Right click your printer and select Properties. Now make the changes to everything prints Black and White or Grayscale. This will make the change effective system wide as opposed to what you did which was for a single print job in a program.
Now, unfortunately, you will still get an error message that your color cartridges are empty anyway because they are.
To disable the error message do this.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable the empty cartridge error on most Epson printers.
Let me know of your results as I am here to FIX your problem. I'm not here to be helpful. I will work with you until this is FIXED or is now FIXED. OK? Use the comment box below to let me know your results.
Regards,
Worldvet
Oct 12, 2008 | Epson Stylus DX6050 All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
