Question about Coleman Powermate Powermate 5000W Generator
I have cummins generator the voltage display on output can i soved the problem
  • 54generator
    54generator May 11, 2010
    What kind of generator: portable, home standby, industrial?
  • 905 Answers
Somehow your post ended up in the wrong category. On some models, 67 indicates a failed inverter. To be more accurate, would need to ask again with correct model and spec numbers.
Posted on Aug 25, 2009
The problem is that the display that shows the voltage and frequency is blank. Is this something easy to repair? Can I use the generator without the display?
The generator should be ok to use with lighting and power tools and suchlike but with equipment incorporating computers and computer equipment it would be wise to get the displays fixed in order to be able to monitor the output and protect the equipment.
Not sure why the display won't work. Displays these days are essentially a low voltage device and so some sort of interface will be employed to reduce the voltage to a suitable level, unless the genny also has a 12 volt output and this is employed to drive the display. Unless you enjoy puzzles a circuit diagram will be necessary.
Jul 11, 2016 | Stanley 5000 watt, 6500 Surge Watt...
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ...
    • 9 MIN
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • 3 MIN
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Did you get this fixed? this is an old post. If not visit www, (Cert Cummins Dealers) They can answer your questions.
    Most likely, rotor slip riings, brushes, control board (if no stator output)
    Oct 20, 2014 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
    Troubleshooting generators
    Not normally, the board outputs to the fuel pump, or LP shut off solenoid. It doesn't know the difference.
    Aug 12, 2014 | Onan CUMMINS 5.5 HGJAB-6755 - Cummins...
    Generac 7000 watt voltage output is 67, why?
    I think either the voltage regulator is going bad (more probably) or your meter is wrong.
    Jul 22, 2014 | Generac Electrical Supplies
    I have an 8.5 onan diesel generator that idles fine but surges badly when the air conditioner is started - the motor races out of control - what could be wrong?
    Is it only when a load is on the unit? I am assuming the voltage output os correct and the HVAC is working properly on shore power and does not have a locked compressor. If it does there is too much demand on the generator and it cannot govern, if the HVAC and ouplut voltages are all good, make sure you have the right weight oil and level in. It sounds like a governor issue, or the engine is mechanically not provifing enough HP. More than likely a governor issue
    Aug 29, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
    My 1000kva cummins generator shuts down during operation indicating low voltage. what is the cause
    Check for floating debris in fuel tank possibly restricting fuel flow thru screen on bottom of fuel pickup;
    Sep 17, 2017 | Pramac Electrical Supplies
    High voltage rpm power generator output
    Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
    Oct 10, 2011 | Coleman Powermate Powermate 5000W...
    I have a honda generator em2500x voltage problem
    My E2500 did this. Turned out to be dirt in the brush holders causing the
    brushes to have less pressure in the slip rings. Stopping and restarting
    joggled the brushes to make better contact until they wore down again.
    Pull your brushes and make sure they slide easily in your holders. Also
    you may need to replace them if they are worn too much or clean the
    slip rings. Good luck. Doing your own repairs is fun.... especially when
    they work.
    Jul 27, 2009 | Electrical Supplies
    67 votage display on generator output.
    Please stop making new problem threads each time you answer, instead post a comment to one of the 5 threads you already have open for this problem. It's getting hard to follow the conversation :-)
    OK, now to the problem. You say you have checked 67 volts is displayed on the generator output, I think this means that you see 67 volts on the control panel display when the generator is running. This can be several different problems:
    a) a bad CT/PT module that tells the controller the wrong voltage
    b) a bad A/D module inside the controller itself
    c) a bad voltage regulator
    Get a real DMM meter and measure the voltages at the top side of the output (large) circuit breaker of the generator. Put the black lead of the meter on the neutral wire and then measure to each of the phase wires on the circuit breaker. If you get normal voltages then you probably have a bad A/D, if you get 67 volts on all 3 phases you have some other problem.
    You still haven't told me what model/spec of generator this is, look on the data sticker on the generator cabinet.
    Dec 14, 2008 | Coleman Powermate Powermate 5000W...
    Coleman Powermate Powermate 5000W Generator Logo
    123 people viewed this question
    Top Coleman Electrical Supplies Experts
    John Trevino
    Craig Butler
    Craig Butler
    Phil Walker
    Phil Walker
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
