Question about Toshiba Satellite Pro A210-EZ2202X Notebook
Lcd problem, colored lines instead of normal display
This is the 4th time. mpstly it comes every 2 weeks but now  it is kinda permanent. the pc works fine though. its a toshiba a210 laptop please help. dont know cause
  • 125 Answers
More than likely it is the lcd cable if you move the lcd does it flicker if so the cable has gone bad
Posted on Jul 27, 2009
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
My dell has issues with the graphics display,at times when i switch it on it just shows a blank greyish black screen,at other times when it works normally it will just start having a background like a tv...
You should try the cheapest solution first. Replace the LCD cable. These should be easy to find on ebay and amazon. My guess is there is a short in the cable.
Nov 29, 2010 | Dell XPS M1330 Notebook
LCD Problem: When i open up the laptop, all it shows is horizontal white and color lines/patches, which covers almost the bottom half part of the screen. The laptop is around 2 years old and this problem...
Sounds like the LCD is failing/failed. Hook up a desktop monitor and see if you have the same problem.
Replacing LCDs is not trivial. Here is a site that sells them. http://www.lcds4less.com/
Google LCD replacement and you'll find many sites.
Sep 03, 2010 | Compaq Presario C700T Notebook
My Display has a permanent white 1" vertical line about 2" from left side on my monitor. Start menu is OK but when loading running anything it is always on the top and makes everythin hard to read,work...
dead lines can be an indicator of a failing LCD screen or inverter. I would take it to a certified repair shop. The inverter should be fairly cheap, the LCD probably not so much.
Apr 18, 2010 | Dell Inspiron 9300 PC Notebook
Dell 710M display has vertical colored lines instead of info
I suspect that the flat wire between you keyboard and screen is coming loose. It is within one of the himges and is about 1" wide and very delicate. You can not fix it and should take it to someone who works on laptops. Sorry that is the best I can suggest
Jul 14, 2009 | Computers & Internet
My T30 display shows the top 3rd of the screen normally. But the bottom 2 3rds of the display has verticle colored lines & display images are not visible. If I hook up an external monitior, I can see...
Sounds like your screen has developed a problem. You wouldn't necessarily see any damage when you opened the bezel up. I would suggest you take it to a repair shop and have them test it and replace the screen if necessary
Jun 09, 2009 | IBM ThinkPad T30 2366 Notebook
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
Occasional colored vertical lines on the screen at startup
base on our experience.... you are looking at a possible screen problem. Is it serious? yes as the screen replacement costs almost half of the total cost of the laptop.
but no harm trying this
1. remove the screws from the LCD bezel, remove the screen
2. detach the cable and reinsert them all both the inverter and the flex cable.
inverter is the circuit usually located at the bottom of the screen and the flex cable is the ribbon that runs from the laptop to the back of the lcd.
reseat them and see if your display improves
Apr 09, 2008 | Sony VAIO PCG-K23 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Sony Viao Display Problem
LCD driver IC or display IC is beginning to malfunction, it COULD be a diode, resistor, capacitor or the IC itself. It will require professional service to diagnose this issue.
Nov 26, 2007 | Computers & Internet
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
