Question about E.Digital Sony DCR-TRV265E camcorder Pal
Firewire stopped working after plugging into my PC
I plugged my Sony 24e camcorder into one computer and it woked perfectly, then plugged it into my newly built PC and it wouldn't work on firewire. Then when I plugged it into the first PC the firewire wouldn't work on that either. A friend brought his Canon camcorder around and it again worked ok on the original PC but failed to operate through the firewire on the new PC. I'm scared that I may have 'blown' the firewire on his camcorder. IOs this possible please?
  • cobbersim Feb 21, 2009
    Sorry about being late in replying to the two replies I received regarding my problem but have been 'out of action for a few weeks. Will check my computers Firewire connections as soon as is possible. Many Thanks. Brian
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand yes, a strong possibility but only if the firewire connector of the new PC has to be manually wired to the jacks on the motherboard (miswired). And an unlikely possibility if the firewire port of the new PC is on a PCI mounted card or built-in to the rear set of connectors. Of course another to check would be is it 4 or 6 pins Firewire port/connector.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
    Novelist:
  • 59 Answers
Hi cobbersim,
While any port can eventually "wear out" over time, it sounds very unlikely that this is what's happening here. From what you've described, I suspect the issue is software-related.
Have you installed the software for your 24e camcorder on your newly-built PC? The driver for the camcorder is almost certainly required in order to operate the camcorder through the firewire connection. If you don't have the driver, you can download it at the following web address (for Windows XP):
http://www.nodevice.com/driver/DCR-HC24E/get39875.html
This might also explain why your friend's Canon camcorder didn't work on your PC - you probably need the driver for his camera in order to operate it from your PC.
If you have the required driver, you might also check to be sure that the firewire connection on your PC is enabled and working properly:
1) Click Start > Control Panel > Performance and Maintenance > System.
2) On the Hardware tab, click Device Manager.
3) Click the "+" next to "IEEE 1394 Bus Host Controllers" (this is the technical name for firewire).
4) Right-click the controller that appears when the category is expanded and select Properties.
5) Verify that, in the "Device Status" pane, it says "This device is working properly."
If it's not, you may need to download a driver for this device. If it's working properly, but you still can't make the camera cooperate, please let me know what software you're trying to use with the camera (or if the camera is simply not recognized at all by your PC), and I'll be happy to offer more suggestions.
Kind regards,
H2H
  • 112 Answers
All computers and camcorders (as well as most pieces of electronic equipment) have what are known as ports. The purpose of a port is to act as a means of transmitting information from one source to another. For example, when you connect a camcorder to a television to watch the video, you are running a composite (also called RCA) cable from the camcorder�s composite-out port to the television�s composite-in port. In connecting a camcorder to a computer, you have at the present three basic scenarios.
1. Firewire
Firewire has become the de facto standard for transferring digital video from the camcorder to the computer and back again. The firewire standard was developed by Apple computer in 1985, and has achieved status with the Institute of Electrical and Electronics Engineers under the standard of IEEE-1394. It is also known i.Link on Sony products or just as "DV", short for Digitial video, on other models. All these terms refer to the same thing.
The basic procedure for connecting a camcorder to a computer with a firewire port is simple. Make sure your camcorder is running on AC power (ie., plugged into an outlet), and leave it off. Connect one end of the firewire cable to the camcorder�s DV port, and the other end to the firewire port on the computer. When the computer is on, turn on the camcorder. The computer should automatically recognize the camcorder.
Firewire is rightly promoted as having a bandwidth of 400 megabits per second; however, digital video being transferred from the camcorder uses very little of this bandwidth and you will still be capturing video in real-time. That is, if you want to transfer an hour of digital video to your computer, it will take an hour to transfer.
2. Analog video capture
If your camcorder doesn�t have a firewire port, or you for whatever reason you can�t or don�t want to use firewire, you have the option of capturing the analog video signal that comes out of the composite or S-video ports and digitizing it into a signal readable by the computer. There are a number of products out there that support this functionality, and many people claim that video captured with an analog process is actually better to work with for certain functions such as bluescreening. For the average home user however, firewire capture is much simpler and much less frustrating.
Analog video capture works by transforming the analog video signal with a hardware device into a digital signal that can be saved on computer. Raw, uncompressed video takes up a lot of space, so it�s compressed with a codec to make it easier to work with. Most of these devices use MJPEG (motion-JPEG) compression, but it is possible with some to use your own codecs, reduce frame rate, resolution or frame size, in order to save space. In this regard analog video capture is much more flexible than firewire capture; with firewire, you must capture at the standard 720x480 / 29.97 fps combination, which means your file sizes will be quite large and there�s nothing you can do about it.
Unfortunately, the success of analog video capture depends heavily on the stability and speed of your computer system. If you don�t have a stable and/or fast system, the video signal will not be transformed fast enough into digital, and you will drop frames. The frustrating part of analog video capture is that there are many variables which affect speed and stability, so even users with 800 mhz machines can see dropped frames and not be able to figure out how to fix it. With firewire capture, dropped frames are comparatively rare.
3. USB capture
More and more camcorders are coming equipped with a USB port. The only reason a USB port exists on a camcorder is to transfer still pictures, not video. The simple fact is that at the moment, USB doesn�t have enough bandwidth to transfer digital video.
R
hi,thaknx for asking fixya
there no problem don,t worry
well. the problem is in your data cable that you use connect to PC
replace your cable and try again if problem still.
then you mast reset you camcorder 1st and try
i am not sure but hopeful your problem will be solved
  • 495 Answers
I think if you exchange the firewire cards between the two PCs, it might solve your problem.
  • Manoj Rout
    Manoj Rout Dec 16, 2008
    First check with the firewire cards if they are working properly. Go to your nearest service center to get a new firewire.
To connect the CCD-TRV35E SONY camcorder to a computer directly
You don't say what kind of computer you are trying to connect to, so I will make a few assumptions. If you have a windows machine it most likely has USB port. Most lower end computers don't come with "firewire" or "anaglog" inputs. You will need to purchase a device (about $50.00) from most suppliers that will accept the ouput of your camcorder (the analog output is the yellow (or some other color) 1/8 in jack that you will plug your cable into , the cable will have one yellow and either one white, or one yellow with two audio connectors (one red and one white) this plugs into the device that you are gonig to purchase. There are also "firewire to USB" devices but they cost more money and are really not worth the extra dollars, in my opinon. Some computers have the firewire input and if this is the case your in luck, just use or buy the firewire or ("digital") cable and plug one end into your camcorder and the other into the computer.
I have 13 computers and 15 camcorders so i do know somethign about this. I just wish you had put more info about your equipment.
Mar 11, 2011 | Sony Handycam CCD-TRV35E Camcorder
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
The pc doesnt seems to detect my cam like it needs a driver or something i plug the firewire and nothing happens
This can be caused by several things. One common problem is a faulty cable. If you have another Firewire/1394 cable, try that.
A second problem is using the wrong cable. I don't remember if the VX2000 takes still photos, but if it does, many Sony camcorders have a USB connection for transferring the still photos. However, the USB connection will NOT transfer video.
A third problem is drivers. This is usually only a problem on older Windows computers. By older, I mean Windows 98, Windows ME, and the first generation of Windows XP (the first generation is "service pack 1"). However, if you have Windows XP and have done updates, then you probably have the correct driver. If you haven't done updates, then you need to get the update for Firewire/1394.
Finally, if you haven't tried re-booting the computer, that very often is needed -- especially with older (more than five years old) -- computers. Even with modern computers, the computer will often get into a state where it won't recognize peripherals. I recommend shutting off the computer completely, disconnecting the camcorder, and then turning off the camcorder. Then, re-start the computer and after it has booted, turn on the camcorder and after it is on, connect the Firewire/1394 cable between the camcorder and the computer.
Hopefully the camcorder connector is OK. I have broken several Sony Firewire connectors, and it costs about $300 to have them repaired.
Jan 14, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
The Firewire connection doesn't work so the Camera will not talk to the computer
Hello there,
To make the camera see your PC is to unplug your camera cables to the PC turn off the PC then when everything is off, plug your camera in with the Firewire cable, then turn on your PC then depending on the camera being on it will then be seen okay.
Jun 07, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
Downloading video from Sony DCR-HC45 Camcorder using a 1394 Firewire. My PC is not recognising the connection. It did work at one stage without any problem but not any longer. What must I do
You have to go on Device Manager and delete the imaging device. Then uninstall old drivers and software used with the camcorder. With 32 bit OS (Win XP and Win 7 32 bit) install Nero 8 Essentails or any other video capture software. Do not plug in external device during install. After installation is complete, reboot your PC. Now you can connect your camcorder with firewire port and then open the nero software. Under video capture, it will detect your sony camcorder.
Jun 13, 2009 | Sony Televison & Video
Making a CD from Sony CCDTRV68 Handycam
I'm using TRV320 camcorder with IEEE 1394 firewire cable 4pin to 6 pin. Your PC also need 1394 firewire plug which should be available in ebay. AV output is for analog signal and you need to use DV in/out plug for digital signal in your camcorder. Good luck -James
Apr 07, 2009 | Sony Handycam CCD-TRV68 Camcorder
Panasonic NV-GS70 lost cd installer
Hi, I purchsed Panasonic NV GS-70 in 2004 and facing the same problem in transferring videos to computer. I tried for firewire cable option as well, but the camcorder does not have a firewire port.
Can anyone suggest what kind of firewire cable to be used for it.
Feb 11, 2008 | Panasonic NV-GS70 Mini DV Digital...
Sony camcorder stopped working
Your batteries have croaked and need to be replaced.
Mar 31, 2017 | Sony Handycam CCD-TRV67 Camcorder
Sony DCR PC105E I-link failure; any advice? (Please!)
Ideas.. 1. Is the camera set the same as before during capture? 2. Does the camera work on another PC or Mac? 3. Look up WinDV on google.com and see if that works. (It's free.)
Sep 14, 2005 | Sony Handycam DCR-PC105E Mini DV Digital...
E.Digital Sony DCR-TRV265E camcorder Pal Logo
29 people viewed this question
Top E.Digital Video Cameras Experts
ivan georgiev
ivan georgiev
Tony Parsons
Tony Parsons
Are you an E.Digital Video Camera Expert? Answer questions, earn points and help others
