Monitors
Problem for Monitors
Generic problem for all Monitors
White screen
By cwis on Dec 13, 2008
I have a mag innovision 22'' lcd screen which goes totally white when turned on Is this repairable?
Same Problem
Mar 24, 2009
-   This is a common 35-D010976 problem. Here's a link to a parts store. But, I do NOT know which part.
Part Number Variations35-d010976
DescriptionMAIN BOARD,PCBA FOR ,A220Your Price$77.39
http://www.encompassparts.com/products/? -   90014
Dec 25, 2008
-   i have a samsung syncamasster 225MW , the screen  is white from when i bought it! sound is coming through (as i am using this as a tv) but there are no images.-   liljak23
Solution #1
posted on Dec 14, 2008
Not Rated)
bammbammfran
Rank: Guru
Rating: 89%, 97 votes
Hi.
Generally an all white screen scenario is caused by no signal from the monitors video board getting to the actual screen.
It could be as simple as a disconnected ribbon cable that mounts the two items.
It could also be a fuse on the back of the actual lcd screens circuit board. These fuses are usually labeled F1.
If you have a tester and the capabilities, in normal running mode the screen should be getting around 5 volts dc at this fuse.
The other problem could be a bad video board. These are not always repairable.
Bammbamm@ptd.net
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
When booting up, my Dell monitor says, "cannot display this video mode", therefore I have...
Answer
my monitor wont switch on
Answer
e211H will not work 1280x768. What setting needs to be changed to accomplish this? I'm trying to not... (More)
Answer
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
