It was my moms laptop and she has asked me to help her fix it she doesnt know what is wrong with it... Can you help?
SOURCE: dell laptop latitude D520 Drivers
The same can be downloaded from here
http://tinyurl.com/2xmbeh
Thanks
proton
Do rate the solution as Fixya or helpful, if you were satisfied with the solution.
SOURCE: Dell Latitude D600 with boot-up error message
You operating system is corrupted meaning that your harddrive has failed or you got a bad virus. Only fix is having the operating system reinstalled and mostly likely that data is lost. Sorry to have to break the news to you and hope that you can get this resolved.
SOURCE: error loading operating system
There is an error on your hard drive. Do an operating system repair.
SOURCE: C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can
only use your keyboard to navigate in this screen). Go to the Advanced
Setup Options ---> then select Boot Priority ---> 1st Boot device
to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10
to save the bios settings and exit. (Your system will re-start
automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or
E in which u have Xp cd contenet.And type If xp content in d:under x
folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
SOURCE: How to Get a good Dell Latitude D520 Laptop
it sounds like you did the right thing, i would search google for "Dell D520 keyboard", you should find many places at different prices, if you havent bought from the site before, try reading some customer feedback, and also, the cheapest may not be the best, look for a good return policy and or warranty for the item. if this helps pleas give a fixya rating thanks
