Question about Panasonic FP-7735 Black and White Copier
Drum for FP-7735 HELP?!
I would like to know how to change the drum for the 7735
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Would reccomend that you get a technician to do this as he will need to reset settings in the copier.
Posted on Oct 12, 2009
My Panasonic FP-7160copier is showing code: c0210. What does it mean?
C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
Exposure density sensor problem. how do l solve it?
If you remove your drum unit, you can see the sensor inside. Make sure it is clean. If the problem returns, check the toner support of the drum unit. It is probably dropping toner onto the sensor. You will also see flecks of toner on your copies if the toner support is bad.
Oct 29, 2009 | Panasonic FP-7735 Black and White Copier
Just changed toner and copies are black
Hello sir; Your machine need to clean mirrow, replace drum and drum blade.
Jun 01, 2009 | Panasonic FP-7735 Black and White Copier
ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
May 05, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Apr 09, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP 7742 Copier
check drum and drum sensor. if the Drum cleaning blade (DCB) has failed and is smearing toner around the drum then the drum sensor can't see the drum. clean it with a brush. the sensor sits in the drum/ cleaning station.
Oct 14, 2008 | Panasonic FP-7735 Black and White Copier
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
How do I get the drum out to replace it
First i must say i,m not an apprentice, i,m 25years knowledge. Thats an oldy. dated 1995-1997. open the front door, to the right under or by developer unit theres a lever, flip it right or left,(cant remeber) this moves the developer unit to the right away from the drum. then between the drum and cleaner unit is a small black cover, remove it, ( about 2in. square) under that is i believe 1 or 2 screws that hold cleaner assy and drum in. Carefully slide them out but first disconnect discharge lamp connectors, maybe remove th #1 charger to prevent drum damage and drop #2 charge assy down out of the way so you dont slide the drum accross it as it comes out. just go slow, maybe the cleaner unit on the left side of the drum unit willstay in the copier. its been awhile since I did one. Dont worry about the bag, thats an old wise tail. I,ve never covered a drum except to keep my sweat from dripping on it in a 102 degree office. , beside they rejuvinate within the first 10 copiers after going back in. good luck, i,ll be here.
Dec 07, 2007 | Panasonic FP-7735 Black and White Copier
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
129 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
