Question about Edimax BR-6104K Router (br6104k)
Dear sir, how r u ? i would like to enter my edimax router 6204wk by net , not by network, ..... i mean i want to enter to it's setup from another city ..... not the same place where is the edimax conected to the pc. thanx in advance .....
To configure the router to router
Posted on Dec 18, 2008
  • 3 more comments
  • jhosua Dec 18, 2008
    i cant connect to router to router
    no,i want to connect the router to router
    pls send my email add i need to support
    this well be coming immediately
    i insured your commentment pls ill be wait as soon as possible
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
My edimax br 6428ns keep on losing its internet connection...i have an internat connection around 30 min but it will stop and i need to run the setup again in order for it to work..
Check the connection type is not "Connect on Demand".
Check the Idle Time Out setting is not used.
This specifies the amount of time the router waits before shutting down an idle connection. This option is only available when "Connect on Demand" is selected. See the manual
Feb 07, 2013 | Edimax Network Br-6428ns Wireless N 300m...
I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
Apr 04, 2012 | Edimax Computers & Internet
Would like to know how to configurethe WPA password for edimax router br6226n
Use an Ethernet cable to connect from one of the LAN ports on the router to the network port on your Windows computer.
Click Start
Click Run
Type CMD
Press Enter
Press Enter
Look for output like: Default Gateway ...
Start Internet Explorer
Press Enter
Login to your router's web-interface
Click to run the Wireless Networking Setup Wizard
Choose 'WPA' or 'WPA2' encryption
Pick a SSID ("network name" for your wireless network)
Pick a password for your network
Click OK to restart the router
Connect via the new SSID/password
Jun 26, 2011 | Edimax BR-6226n nLite Wireless Broadband...
How can I put password on my wireless router ?
Do you mean that you need to put a Password for the "Wireless Network"? i.e. network key or password to access to your wireless connection.
Access to your router, Click on "Home" then click "General Setup" icon, then you click on the "Wireless icon" check on "Security Settings" and set your "Encryption Key" (There are 4 Encryption Keys, setting one will do.
Hope it helps.
Apr 24, 2011 | Edimax BR-6226n nLite Wireless Broadband...
I cant acces to
If I'm not mistaken, you can't get to the user name password page unless you have already accessed the edimax setup page after typing 192.628.2.1, thus the solutions provided by some of our friends might not be of help.
Jan 09, 2009 | Edimax BR-6104K Router (br6104k)
How to change dns
I am not familiar with Edimax, personally...however, you can find out a lot of information by understanding a bit about the computer attached to it.
It's a home network
You are running a Windows machine
Your windows machine is connected to the Edimax router
Your Edimax router is also your default gateway
drop to a command prompt (start, run, CMD, enter)
Type ipconfig and hit enter
This will get you your IP address of your local machine as well as the subnet mask and the default gateway.
Once you have the default gateway, you can connect to it via Internet Explorer. You will need to set it up as (where the IP address is your default gateway)
At that point, you will need your router password
Once you get in, you can then poke through your settings and manually change the ones you need.
Hope this helps.
Nov 11, 2008 | Edimax Computers & Internet
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Frequent disconnection of internet service
HI rodelio,
Please give me the backbone of your committed internet rate (CIR), is it burstable bandwidth?  Actually router  is designed for Network Address Translation (NAT) which means it is better to have fast ISP that has committed internet rate (CIR). It is constantly happened for internet connectivity fluctuation cause of very low CIR specially when you are connected with more than 3 computers on the network setup.
Much better to used proxy server with linux, or Kerio Route Firewall for better performance of your browsing.
I am glad if you can extend your problem to me. I am here to help you.
Best regards,
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router (br6104k) Logo
59 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
