Home | Toshiba | CF36G40 36" TV | Big black box across the...
Toshiba CF36G40 36" TV
Problem for Toshiba CF36G40 36" TV
Big black box across the screen towards the bottom.
By voigt2004 on Dec 13, 2008
I was trying to program my DVR remote to work with my toshiba cf36g40 and all of a sudden a big black box appeared around the area that the volume screen comes up when changing the volume. it goes away for a min or two if i turn the tv off and it doesnt show up if on regular tv, just when the tv is turned to tv/video. i tried switchin to just a coax cable instead of the red white and yellow cables... not tech savvy sorry. please help.
Comments:
Dec 13, 2008
- this is a 35" screen. Approx 15yr's old. Only 1 RCA input w/coax and S cable. All inputs have the same result. Yet the the black box does not appear with static on any random channel. The box is on the lower 1/3 of the screen centered and streching to 2" away from the edges. Box will disappear if menu or volume is used. Can take up to 10 seconds to appear. This all occured after attempting to program a universal remote for a dvr. Yet this has noting to do with the DVR. The DVD player and direct input all have the same result. Thank you in advance for your help. This TV weighs over 100lbs. I would hate to have to move it again.
Same Problem
Jan 28, 2009
-   I have the same problem, however the black box just randomly appeared. When I change channels, it goes away for a second but then comes right back. I have tried unplugging everything and it is still there.
HELP!!!-   avog55
Dec 29, 2008
-   I have the same problem recently. For awhile it would go away if I turned everything off, then back on but now that isn't even working. Any solutions?
-   havesian
Dec 26, 2008
-   I have the same problem- - I thought it was my dvd player so I switched it out for a new one- and now it is doing it with the XBOX-   Guest
Solution #1
posted on Dec 13, 2008
Somewhat Helpful)
likha
Rank: Wiz
Rating: 82%, 582 votes
hi
can you tell me the exact complaint to your unit? and i will help you!
Thanks!
Was this helpful?
Yes
No
Solution #2
posted on Jul 25, 2009
Not Rated)
sgmarshall
Rank: Apprentice
Rating: 0%, 0 votes
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Was this helpful?
Yes
No
Popular Solutions for Toshiba CF36G40 36" TV
Questions and Unsolved Problems for Toshiba CF36G40 36" TV
Do you recommend Toshiba CF36G40 36" TV?
Answer
Answer
trying to remove a horizontal line from the left of the tv.plz help.
Answer
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to... (More)
Answer
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable... (More)
Answer
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden... (More)
Answer
I have a Toshiba TV (model# 23319197). The audio output ic part is out and Toshiba has discontinued... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba CF36G40 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
