Question about Marantz SR-4200 Receiver
Marantz SR4002 stuck in HP mode
I turned the amp on today from it working fine last night and it went in to HP mode, I don't possess any headphones! How can I turn this mode off? I have tried every button combination I can think off. Is there a factory reset switch anywhere?
4 Suggested Answers
  • 4234 Answers
SOURCE: Power is connected to unit.
The unit is in "protect" mode. This means that there is a problem in the final output section. The most common fault is bad output transistors. Expect a parts cost of abput $15-$30 in parts plus the local labor rate for a repair cost.
Dan
Posted on Apr 02, 2008
SOURCE: marantz sr4002 amp standby light flashing
did you ever find a solution? I am having the same issue. rabigelow@gmail.com
Posted on May 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: Marantz sr4002 - Power light
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 23, 2011
Marrantz sr4002 blinking stand-by button
If you've checked all your speaker connections and there is no short, reset the amp by holding down the "S. Speaker B", "ATT", and "EXIT" buttons for three seconds.
Jan 20, 2013 | Marantz SR4002
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Hi, I have a SR4002 AV surround receiver and I can no longer get my speakers or subwoofer to work. I have noted that the display reads analogue and I cannot get it to switch back to digital. I have done...
A setting on the receiver is the problem. Open the manual and examine every indicator for clues. Blown subs don't make settings change.
Page 39 for digital and other modes.
http://www.retrevo.com/support/Marantz-SR4002-Receivers-manual/id/6753ci476/t/2/
Run the speaker setup routines to test their function.
Aug 22, 2011 | Marantz SR4002
Standby light blinking
if you have the blinking led problem on your SR4002 receiver, it is in protect / safe mode 1- turn on you receiver2- hold 'S speaker B' + 'ATT' + 'exit' buttons at the same time for 3 seconds3- it should turn back on normally
Feb 26, 2011 | Marantz SR4002
Cannot get jamo 250 subwoofer to work via marantz SR4002. Have power but no sound. Also are trying to connect PS3 via HDMI which is no probs however, cannot connect via optical audio
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Nov 02, 2009 | Marantz SR4002
Marantz sr4002 amp standby light flashing
Sep 06, 2009 | Marantz SR4002
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Marantz SR4002 - blink standby
pull the power for about 15 minutes, then plug it back in and try it again, if still no work, then you need to get it looked at by marantz...
Feb 19, 2009 | Marantz SR4002
Marantz SR-4200 Receiver Logo
64 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
