Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
RAM issues. Not getting the amount i have installed.
I am running 1.5 gb of pc 4200 RAM in an acer aspire E380. I installed a fourth stick of 512 today. To my surprise i booted to a memory dump, aka. Blue screen of death. I quickly removed power from the system and then removed the fourth stick. I booted a second time and had to let Vista run a repair due to the crash. After the check was run windows determined i had "errors" on my C: drive. I let chkdsk run its self on startup. I rolled back to a working date. Now here is where i am stumped. I can not get my back four USB ports to run my mouse, it will accept my usb keyboard, but not mouse. Also i have 1.5 gb of memory installed as i stated earlier. On boot acer has a widget setup that will tell you the amount of ram that is currently available. Since this blue screen, i can only access 128 mb of my total 1.5 gb installed. meaning it is only accepting one stick of 512. what happened to the other 2? I have spent all day looking and attempting to fix this issue, the more i try the more i get frustrated. i am ready to throw my pc out the window and start from scratch. Any help you can give me would be greatly appreciated, Thank you ,
Issue solved. I found that my thirs slot for my ram is completeley fried. Have no idea as to how it happened, it must be a default problem from the company. But i had to remove all the ram and hold my power button down for 30 seconds with the cord disconnected to reset. Of course acer was no help in this issue and wanted to charge for information, thanks to all those who post on forums. You saved my a bunch of money.
Posted on Dec 18, 2008
I tried to upgrade my acer aspire one A150 to a 2 GB stick of ram - didn't work so reinstalled the 512 stick I had (SHOULD be a total of 1 mb counting the 512 onboard.) It is NOW only recognizing 512. ...
Try swapping the ram sticks with each other and see if it still reports 512. If it does...then it sounds like you damaged one of the seats for the RAM somehow. Did you have any static shocks occur?
Mar 02, 2011 | Acer Computers & Internet
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
I can't get my Acer aspire e380 to accept another
How many slots for RAM in the motherboard?
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Jan 23, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire Memory problem
check hardware compatability,vista is touchy,get xp
Sep 23, 2009 | Acer Aspire 5315 Notebook
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Ram Upgrade Problem
There is nothing wrong and your install is OK.
The laptop has used some of the RAM as video RAM for the video card that is part of the motherboard.
You should have noticed that with a single 512Mb RAM you would not have the full 512Mb RAM available to you, the video has grabbed 128Mb of RAM.
Jan 01, 2009 | Acer Aspire 3610 Notebook
Compatability of Memory Upgrade
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Jun 04, 2008 | Acer Aspireā„¢ T180 PC Desktop
Acer Aspire E380 memory
Hi pimp69,
You can only use components compatible with Aspire series computers. Before you choose new components, please ask your authorized Acer dealer whether the part will operate within your Aspire series system. This is noted in your manual pg. 6.
Compatible memory for your Acer. Don't forget your Acer uses an intergrated graphics card that uses your system memory to function.
Good Luck & Kind Regards.
Mar 19, 2008 | Computers & Internet
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
