Question about Sony VAIO PCV-W1 PC Desktop
Sony PCV-W1 how to ge to the hard drive
Yea looking at the casing, how the hell do you get to the hard drive, what screws do you undo??? cheers for your support
Quite simple really.
Turn the unit around so the screen is facing away from you, then, with the unit still upright, look at the bottom of the unit (not the base) and there should be two rubber protectors covering the screws of the panel. If you turn the unit to the left and to the right, still concentrating on the bottom, you will see screws (unprotected) on either side.
Remove all four screws and pop the back off (some force may be required but not too much since you may end up breaking the teeth that hold the case in place when you put it back on). The hard drive caddy is located at the bottom of the unit and is held in place by 4 screws.
Posted on Mar 16, 2009
Looking for sony vaio pcv w1 g recovery dvd, no problem to pay for it
Contact sony.http://www.sony.co.uk/support/en/product/PCV-W1_G
Dec 09, 2012 | Sony VAIO PCV-W1 PC Desktop
I need to replace the DVD disk drive on my Sony VAIO PCV-RX580. I was able to remove the left side case cover but cannot figure out how to remove the other panels. Can you give me some assistance? Thanks -...
I also have a sony vaio but in replacing my drive I only had to remove the one side and two screws. Then push the drive from the front. the drive is "clipped" in there." It will come loose and just remove and replace. Good Luck
Mar 24, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
I have a sony vaio pcv-w1 desktop computer,is there a way in resetting back to manufactory settings without a recovery disk
no there is no way to recover it back if you diddnt did the recovery disk when you bought your computer.
Jan 25, 2010 | Sony VAIO PCV-W1 PC Desktop
I need instructions on how to take apart the sony vaio pcv-w1
START BY SLIDING PANEL OFF TO REVEAL MEMORY MODULE.NOW LOOK DOWN JUST BEHIND SCREEN,YOU WILL SEE 2 BLACK SCREWS.UNDO THE SCREWS AND RELEASE SMALL PANEL.NOW UNPLUG WIRING HARNESSES ALLOWING THE SCREEN TO BE DETATCHED.WITH PANEL MISSING YOU SHOULD HAVE EXPOSED 4 GOLD SCREWS.CAREFULLY WITH A LONG PHILLIPS SCREWDRIVER RELEASE SCREWS.THE SCREEN WITH A SMALL WIGGLE WILL NOW BECOME DETATCHED.RELEASE THE FOOT OF THE P.C BY UNSCREWING 2 PHILLIPS UNDERNEATH,THEN PROGRESS AROUND THE UNIT TAKING OUT ALL BLACK AND GOLD SCREWS.THERE ARE ALSO TWO SCREWS CONCEALED UNDER THE RUBBER LUGS ON THE BACK SIDE OF THE P.C.JUST REMEMBER WHERE YOU HAVE TAKEN SCREWS FROM.ALL THE BEST TECH HEADS charlie c
Dec 15, 2009 | Sony VAIO PCV-W510G PC Desktop
Where do I purchase a hard drie
You can purchase hard drives on line and at any computer store in your area.
Nov 16, 2009 | Sony VAIO PCV-W1 PC Desktop
How to replace rewriter
there is s screw with a circuil drawing and you must remove the key board to see it and then you will be able to replace the rewiter
Oct 05, 2009 | Sony VAIO PCV-W1 PC Desktop
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Sony VAIO PCV-W1 PC Desktop Logo
345 people viewed this question
Top Sony Computers & Internet Experts
Computer Links
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
