I have a MSI K8TM-ILSR m/b in a Antec Aria case with a card reader. When I try to install WinXP pro, it wants to choose F as the drive to install the OS. Any idea as to why XP chooses F and not C as the drive letter.Kindest regards.Tim Lumsden.waimang2@gmail.com
  • waimang2 Dec 13, 2008
    Hi. Thanks for the quick responce.
    I figured it all out. The "card reader" that was attached to a USB port on the mother board, was seen by winxp as a physical drive and had assigned it drive letters which stopped the main HD from being asigned the drive letter C and gave it F instead.
    Removing all cable connections from USB ports on the motherboard fixed the problem. Win XP is now on primary HD, drive letter C.
    Whooohooo!
    Scholar:
  • 94 Answers
Because 'f' is the first accessable drive to XP, that does not have an OS already installed.
It could also be a usb drive - remove it and ty again
Posted on Dec 13, 2008
Hi, From where can I download a manual for the MSI-649T Pro VER 5 ?
Click here to download the Manual for MSI K7N2 Delta-ILSR from MSI Official Support
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | MSI K7N2 Delta-ILSR Motherboard
Gateway PC into Antec enclosure?
Hi:
You should be able to transfer your motherboard to the new case, but some things to check before you do:
How do the power switches and front audio/USB connections work for the old gateway? Are they standard or vendor specific? Are the optical drives in the gateway standard, or do they have special fronts on them? I have done what you are wanting to do several times, and often you need to replace OEM optical drives, and sometimes the motherboard headers don't match up with a builder case, so you do the best you can.
Dec 11, 2009 | Antec Aria - MicroATX Cube Case W/Power...
MSi Motherboard suddenly stopped seeing My IDE drives/ CD/DVD
Could quite simply be that its the IDE plug on the motherboard that's gone. If that's the case, you'll probably need a new motherboard.
As far as I can see, you've done pretty much everything that can be done to make sure it's not the motherboard.
Good Luck
Sep 23, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Manual required for EMachine 6250 desktop pc
I found a website that stated that you model e-machine has a MSI motherboard (K8TM-ILSR) MS-6741
Here is the link; see if it reall is the same board and download the manual from there:
http://www.msi.com/index.php?func=proddesc&maincat_no=1∏_no=575
Apr 01, 2009 | Computers & Internet
MSI MOTHERBOARD - MS-6741 Ver:1 I have installed a 5 in 1 reader
yoyo
on the usb header on your motherboard 1 will have four pins and the lower row will have 5 or the other way around.......
the usb wires go as follows
red, white, green and black
top row left is red then white then green then the black this goes for the bottom row also is your card reader has to usb leads....
hope this helps
Rik
Jan 29, 2009 | MSI K8MM-ILSR Motherboard
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Computers & Internet Logo
David Payne
David Payne
