Question about Sony KP-53XBR200 53" Rear Projection Television
52 inch projection sony
I got this from my work it works fine but its in black and white the colors gone,but if i go to pic in pic the small screen is in color but not main screen.
    Genius:
  • 1,199 Answers
Check settings on main screen go into menu to change settings///also you can try resetting it by unpluging for five min....replace plug ...now PUSH AND HOLD thepower button for 10 seconds
Posted on Dec 13, 2008
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
How do you adjust color guns in an rgb projector?
I LEFT MY TV ON AND WENT TO WORK, WHEN I CAME BACK 12 HOURS LATER THE COLORS WERE GONE . NOW I SEE ONLY BLACK AND WHITE.
ITS A SONY 48 INCH PROJECTOR TV.
Sep 18, 2008 | Televison & Video
Older 90's projection screen. 52 inch
Try opening up the front cover under the speaker outer cover, most speaker fronts should just pull off if you don't see any screws holding it secure near the side close to the front cover. Then there is about 4 or 5 screws that hold the front inner cover on. You are looking for a small black box with 6 adjusting screws . Three of these are for adjusting the focus and three are for adjusting the amount of current going to the CRT's. The markings are very small but you can try turning the Blue screw down and that will decrease the blue ( marked with a B). But if this just makes the other colors seem more powerful you may have a bad blue CRT. There is adjustments for three color CRT's ,Blue , Green and Red, try playing with the Blue and try to get it the way you think it should look but if the Blue just does not want to work right the Blue crt is probably gone.
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
Need help.
You need the ITC222 convergence power supply board. You can get a new replacement board at the following link.
http://servicemanuals.vstore.ca/
Aug 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Apr 10, 2008 | Zenith B50M88W 50" Rear Projection...
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
Sony Rear Projection TV Model # KP 53N74
I have had a similar issue with a Sony 52" circa 2001 tv. It was bad and then got better. The only problem now is that when I plug anything into the component 1-5 (but not 4) the screen is fuzzy. The DVD is plugged into 4 and it works fine. I tried plugging something else into that and it showed up in black and white. Very frustrating. Fancy TV if you only watch cable or a DVD. All other modes show up fuzzy. Sony recommended a tv repair place in St. Paul but they want around $400 just to look at it.
Sep 26, 2007 | Televison & Video
Sony KP-53XBR200 53" Rear Projection Television Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
