Question about Kenwood VR-5090 5.1 Channels Receiver
Kenwood vr-5090 only plays stereo
We have no sound on digital output, only stereo. Our dolby, pcm or analog modes won't work. This receiver worked fine for a while, then we hit a button on the remote that made several things not work. We paid a technician to "fix" the problem, and when he left (after rewiring things) the sound cut out all the time and we had only stereo. We rewired some things and the sound doesn't cut out, but we still have no digital, dolby, etc. The guy we hired said dolby would never work with our old tv, but it worked fine before. The manual states, "DSP Modes can be selected only when THX mode is OFF. When the input is a 96k fs PCM signal, it is only stereo that can be selected." What does this mean?
3 Suggested Answers
SOURCE:
  • 7 Answers
SOURCE: Kenwood VR-407 always stays in Stereo mode
You will need to go to audio set up and make sure it is set up to play with a center chanel if you have one as well as the surrounds. You can also only have side a speakers selected when trying to use surround. If you have b selected it will play in stereo only
Posted on Aug 25, 2009
  • 506 Answers
SOURCE: Kenwood VR-5090
Probably an issue with the switching power supply or possibly a shorted output. There are various protection circuits that will cause that. Most suspect is the SMPS (switch mode power supply) fault detection. (Check your output for a short though, i.e.shorted speaker wires)
Posted on Dec 13, 2009
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Cant get sound from right and left rear speakers
Your source will determine the Dolby Digital capabilities. WHAT is on video 1 and is it Dolby Digital?
Jul 04, 2010 | Kenwood VR-407 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Jul 26, 2009 | Kenwood VR-407 Receiver
No sound output
hiya
have you checked the thermal fuses inside... they may of blown replacing the fuse may sort this out
Feb 26, 2009 | Audio Players & Recorders
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
Kenwood vr-7080
Is your tv wired to a cable box or an HD antenna?
Case 1: If your signal is weak, then the chances are that the feedback from your tv to the receiver's processor cannot interpret a Dolby Digital signal.
Case 2: Check the TV MENU AUDIO setting. Does your TV have a ON/OFF feature for the optical output, or any aux. speaker outputs?
Aug 04, 2008 | Kenwood VR-7080 Receiver
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Kenwood VR-5090 5.1 Channels Receiver Logo
79 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
