Question about Panasonic SC-PT960 Theater System with Wireless Speakers
My wireless speakers are not working i don't know why
  • NewMom18 Dec 16, 2008
    My wireless connection between my panasonic home theater system and the rear wireless access point will not connect.
After some research i came with the solution!!! First Turn off the home theater and turn it on again,lower the volume completely. Then on the dvd unit press the fast forward key>>>> while at the same time you press the number 3 on the remote control. A letter p is going to show oh the display. When this is happening there is a small button on the receiver on the back, you might need a thin object to reach the botton and press it. Press it once and the light will change from red to green. To finish up repeat the fast forwar>>>> key on the unit while pressing #3 on the controller and boom!!!!! the w1 will stop flashing and your surround speakers are rocking!!!!! enjoy it!!!!!!
Posted on Jun 18, 2009
  • 1 more comment
  • ajinesta Dec 29, 2010
    Excelent it worked for SA-PT750 Home Thearer too!!! Thanks
  • Ruth LaMarr
    Ruth LaMarr Nov 12, 2013
    Thank you! This worked for me also!
  • Tanya Biddle
    Tanya Biddle Dec 01, 2016
    Tried this fix and the red light stayed red, never turned green. Does that mean the WiFi unit has had it?
  • 21 Answers
Hey , i knowwhat the prob is.. there is no prob!! PT960 wireless speakers are like that.. they are very low in volume.. but you can manually adjust the wireless speakers volume.. go to setup and then increase the rear speakers volume 2 or 3 points.. I have mine increased 2 points.. then you will hear the diff..
but if you still don't hear anything, go to TEST and test the speakers.. and check ll the connections and the green light in ur transmiter..
THIS WILL FIX YA'!!
Posted on May 28, 2009
    Genius:
  • 1,199 Answers
Is there a channel setting? If so make sure all chanels are on the same setting....speakers and transmitter!This should fix ya!
Posted on Dec 13, 2008
I have a JBL wireless flip speaker and even after reading the so-called manual, I have absolutely NO idea how to use it . My iPad has blue tooth capability but,I,don,t even know what,exactly is Bluetooth...
Once you put the JBL speaker on, turn on bluetooth on your ipad, search for bluetooth device, it takes a few minutes sometime to locate your speaker, once you see your speaker listed in the bluetooth device, click on the device. IT will connect but at times it might ask for a PIN.
Oct 01, 2013 | Radio Communications
No factory speakers working
You don't mention the year/make/model of the vehicle so, my response will be as vague as your problem/question. Either the speakers are not connected properly, defective or, your factory amp ( no way of knowing because you don't mention the vehicle) is not powered up or not working.
Oct 15, 2012 | Pioneer Car Audio & Video
My left speaker is not working and it isn't the cable connection. It has been checked and the plug is in all-the-way.
You could just have a loose wire inside the speaker but sometimes one speaker will just go to speaker heaven. Sorry I can't give a better answer and I don't know that brand so I don't know if you can open up the speaker easily to see if there is a loose connection. Now, sometimes the plugs can just wear out too which can be replaced if it is a great set of speakers but again, back to the lack of knowledge about that brand and how hard it is to work on.
May 22, 2012 | JBL Audio Players & Recorders
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
Wireless speakers are not connecting to the box all the other speakers are working except for the two wireless ones we have followed all of the instructions in the manual but they still are not working the...
Wireless speakers needs power to run ,unless they are powered by battery (to be loaded into speaker modules) ,I believe you connected each of the wireless speaker to 110 VAC power plug and the transmitter module as well..
Before connecting them to your Samsung htd-d550 ,I recommend you test them with something else,i.e..NOTEBOOK Audio output or MP3 player headphones output...
if you succeed then you can connect it to your Samsung..
Please make a simple test to make sure wireless speakers are working and if you need more help just let me know ..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 25, 2011 | Audio Players & Recorders
I have a avol aht480w surround sound system 5.1 with wireless back speakers my issue is that my center both my front and my sub aren't working only the two wireless ones
If you no longer want this system, i am in desperate need of a remote control for this system. I don't even see this listed on AVOL's product website!
Oct 10, 2010 | Audio Players & Recorders
Audio problems on : nx5000
Hello. What is the brand and model of your laptop. Also, what operating system are you running?
Oct 09, 2007 | HP Compaq nx5000 Notebook
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
2,020 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
