Question about Harman Kardon AVR 70
Avr70 I have a reciever model AVR 70 four years and when I turn it on the sound goes off or it turns off by itself
    Genius:
  • 1,199 Answers
This sounds like a short circut in the wireing!check back of system to make sure nothing is touching!
Posted on Dec 13, 2008
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Problem with Harman Kardon AVR-70II Turning on
you must open the receiver in order to Test the relais for dirty contacts or faulty. Try to clean the contacts with contacts cleaner, or see any loose wires around and resolder the wires from coil
God bless you
Oct 11, 2013 | Harman Kardon AVR 70
HK AVR70 Unit has been fine. Not sure what happened? With the volume turned up loud you only hear 5% of the sound coming out of the speakers.
Sounds like either the speakers are bad or the output stage is bad. Try different speakers and if not, then the electronics will need to be diagnosed.
Jun 26, 2011 | Harman Kardon AVR 70
Problem with the Denon AVR-4802 7.1 Channels Receiver Denon avr-4802 h/p input issues. Ads by Google Custom Cable Installation www.consolidateddatacom.com/Network and Data Cabling for your business....
you need to find a headphones, put a drop of contact cleaner on headphone plug and plug it into receiver's h/p input several times. It cleanes internal h/p connector contacts and unit will work fine. If doen't help the receiver most likely has bad h/p connector soldering.
Jan 20, 2011 | Denon AVR-4802 Receiver
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Denon AVR 3600 sound gone
this happened to me once and I found that my reciever would just shut down. make sure that you have plenty of space above the amp. it may be over heating and shutting down on you and when it cools down, it turns back on. there will most likely the "overload" light will be lit when it shuts down the audio.
hope that helps
Dec 31, 2008 | Denon AVR-3600
Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Jul 22, 2007 | Denon AVR-2802
178 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
