Question about Rockford Fosgate T10001 bd Car Audio Amplifier
Best sub For RF T10001
I have a 94 Ranger XLT With 25th ann Kenwood , Rf 400-4 10farad cap, yellow top optima. I was just wondering what the best move was with small backspace sealed or ported??? Also what in your opinion is the best sub I was looking at the 12 w7, is it worth the money or should I go with solox 10 or L7???
I am running 2 t10001bd amps and I am running the fosgate t2 12" subs with dual 2 ohm voice coils. I pounds. The only problem is you need a lot of space and the subs are very expensive. Got mine for a good deal at $300 each msrp $799
Posted on Feb 13, 2009
  • 15,935 Answers
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Posted on Dec 22, 2008
1994 Suzuki RF 600 R fuel line diagram.
Hi, Seth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1994 Suzuki RF 600 fuel line diagram Google Search
Suzuki 1994 RF600R Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki
Suzuki RF 600 1994
Mar 16, 2017 | 1994 Suzuki RF 600 R
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
I have a ranger cb radio and it just started where I could not hear anyone. I turned the volume all the way up and can hear people if they are close to me but not far away. The needle doesnt move when I tx...
It sounds like something has gone bad in the receive section of the radio.
It could be the RF gain knob is no good.(make sure its turned all the way up.
It could be a resistor on the board loosing value in the receive section. If your radio only has 1/6th watt resistors, its very likely.
At any rate, if its not something simple like a bad RF gain knob, or that you just don't have it turned up, then its going to need a tech.
Unless you have a schematic and service manual and have time to trace it down.
Some things you can try..
Double check all the usual stuff, no matter how simple. Coax, antenna, grounds etc.
then, you can open the cover of the radio, look at the wires connected to the RF gain knob. Should be 2 wires. If you have a soldering iron, you can unsolder them and hot wire them together. this will make your RF gain full.
If its not working after that, it needs a tech to find the bad part.
If you turn off the radio, and disconnect the power wire for a long period of time, and then hook it up and turn it on and the receive is there for several minutes and fades away, its most likely a bad resistor. When it gets warm from running, it looses value.
It could be a resistor loosing value, a cap unloading when it shouldn't. It needs some one who knows how to trace this stuff down on the board.
My best guess without having the radio here with my meter is that a resistor has gone bad. its been known to happen especially if the radio has really small, 1/6th watt resistors. Depending on when it was made, it may have them.
the other thing that could have happened is that if a big radio keyed up next to you, with a lot of wattage, it could have blown the receive.
Nov 19, 2009 | Ranger Communications RCI-6900F-25 CB...
How do i connect my xbox 360 to a big screen tv like the box ones,with a rf modulator?
Hello there:
You will need the red/yellow/white video cables and just hook up the yelow and white up to the xbox and the other end yellow and white to the tv than turn the tv to channel 3 and this should work
best regards mike
Jul 30, 2009 | Dynex RF Modulator AV Signal Converter
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Televison & Video
How do you get surround sound to work on regular tv?
Depends on what you're looking for. If you're running just a RF cable, then you'll have to get a RF adapter that allows for sound output to AV and display through the RF. If you have AV in the back of your TV, the three colored prong connectors (red yellow and white) you can simply pull the red and white away and run them to your sound unit. Mind you, the best of sound quality can only come from higher quality digital output.
These range from optical to HDMI styles, and are the best ways to go. I hope this helps you out bud. :) If there's anything else I can help with, don't be afraid to ask.
Sep 13, 2008 | JVC EX-D5 System
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Oct 23, 2007 | Car Audio & Video
Rockford Fosgate T10001 bd Car Audio Amplifier Logo
142 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
