Question about Hoover HDC6 Electric Dryer
Tumble dryer I have a problem with my Hoover condenser dryer, it has been working efficiently for over 5 years but has now doesnt work properly. When i press the on button, a buzzer sounds and then when i release the button it stops. If i hold the button down for a long time then the alarm starts and the machine works as normal! can any one suggest any helpful advise? My husband and i have cleaned it thoroughly and it stills causes problems.
  • Anonymous Nov 21, 2007
    when i press the button to start a buzzer sounds
I've had the same problem and bought a relay, as suggested. It cost me under £20 and took me minutes to fix. Saved me hundreds on a new tumble dryer. And whats amazing, is that I'm a housewife with no tech knowledge. So Thanks.
Posted on Mar 16, 2008
    President:
  • 1,462 Answers
Take the top off. there should be a small relay board to the right just behind the fascia. the fault probably lies in that board - relay not holding in
Posted on Apr 04, 2007
Hoover tumble dryer - condenser wont fit back in?
I would need to be there to see what you have going on, sorry,.
Sep 28, 2016 | Hoover Dryers
Hoover tumble dryer infinity vison hd condenser keeps tripping after about 3 seconds only had it 6mths? tried fuses, all filters clear and empty.
have you cleaned the condenser down at the bottom of the dryer and pull it out and put hose through it and look in where you have taking it out and make sure its clean and take off back off the machine and see if the element is wet leave it to dry out and if that doesnt help check if the water is going in the tank or your pump could be faulty
Apr 06, 2014 | Dryers
My Hoover HD condenser dryer won't give out any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 19, 2011 | Hoover Dryers
I have a TB condensing tumble dryer, model TM310W, which has always worked well, but lately, although the clothes are drying, there doesn't seem to be much water going into the reservoir. I can't find it...
The first decision you must make when buying a tumble dryer is whether to buy a vented or a condenser dryer. As you'd expect, there are pros and cons for both. This page helps you understand all of the differences, including the reliability and repair implications. Condensor tumble dryers are becoming more popular but vented tumble dryers still have some advantages and the convenience of not needing a venting hose (as always) requires some compromises.
Until I can put together my own reviews the best Tumble Dryer reviews available online are by Which?
Due to their resources and independence, Which? usually have the latest reviews and collect the opinions and experiences of thousands of members - Which? tumble dryer reviews (Plenty of free information but will need to be a subscriber (take advantage of the 1 month trial offer to get the full benefit)
Vented tumble dryers are cheaper than condenser dryers, they are also simpler, more reliable and more economical to run. According to Which? "on average, vented tumble dryers use about a fifth less energy than condenser dryers to dry a full load of cottons."
So why bother with a condenser tumble dryer? Well condenser tumble dryers are a convenience product but they do offer a solution to a genuine problem for some where venting the dryer outside is difficult or even impossible.
My advice would be that if your tumble dryer can be sited somewhere that allows you to correctly vent it outside, either through a wall or through a window, then a vented dryer is probably best. If this would be particularly awkward, then buy a good quality condenser dryer, which should condense the steam into water.
Modern washing machines now have a far superior spin speed, and, of the ones we recommend, the cheaper model has a 1200 spin speed, the other a 1400 spin speed... so your washing will be fairly reasonable (some items could be about ready to iron) and this, in turn, could affect your other choices.
Could you get away with just airers and a washing line? Or have you considered a dehumidifier?
A Spin Dryer... will work efficiently, and is cheap. The main advantage to it is that it is only the size of a large pedal bin, so it can be stored under the worktop in a small amount of space.
A Tumble Dryer... much more expensive... for a decent quality item you need to pay a quite steep price. They do a good job, but are another full size kitchen appliance to find room for.
A Washer/Dryer... instead of a washing machine... disadvantages, if it goes wrong then you have no back up in either the washing or drying department... and of course being a more complicated piece of machinery, it IS more likely to break down! The only advantage is that it will be a space saving item.]
please comment on these on how helpful.
Dec 21, 2010 | Electrolux Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
9kg hoover vhc392t - condenser drawer is not getting any water in, although the clothes get dry - how can this be? I have dried four loads and there is no water in the condenser
I can't help you with your problem except to say you're not the only one. Same model same problem. After 2+ years of running ok exactly this problem has developed. I'll let you know if I find out the solution.
Jan 08, 2010 | Hoover Dryers
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Hoover HDC6 Electric Dryer Logo
684 people viewed this question
Top Hoover Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
