Question about Water Heaters
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The filter is clean and the connections seem intact...any ideas?
  • 1 more comment
  • witchratt Dec 22, 2008
    I have the exact same problem as above and would appreciate any suggestions. Thanks!
    This is a followup to my previous post: I have also tried putting in a new thermostat and I still have the same result. Thanks again.
  • dmgarcia326 Mar 25, 2009
    I also have the same problem with the Criterion II. The ignitor sparks but won't light the pilot once in a while. Usually by the second time it will light. However, my HVAC company told me I should get it fixed. they first replaced the motherboard, which didn't solve the problem. They then replaced the gas valve, which didn't solve the problem. They then came over and "made the spark bigger." that also did not solve the problem. That tech told me that is the way these ignitors work. My furnace is less that 5 years old so is still under warranty. The parts were paid for but I had to pay $200 labor. I had them come back again after we had some extensive remodeling. The HVAC guy told me it was because there was dust from the remodeling. I am having another firm come tomorrow and clean and check it. I have thought all along if the ignitor is not starting the furnace, it is logical to me that the ignitor would be the problem. We will see what a different HVAC firm says tomorrow. I will no longer use Golden Seal that charged me, but did not fix my furnace. I feel they were just throwing parts at it. Any suggestions would be appreciated.
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Posted on Dec 28, 2008
  • leeCA Jan 13, 2011
    I found that the preasure switch is the problem if the igniter is not. Take the igniter in the garage and put 110 v to it-if it ignites - check the preasure switch (little round thing with the rubber hose attached. Disconnect blow and **** - should hear clicking. if not replace it - it should then work. Part is $ 27 depending on the furnace.
  • 101 Answers
Hi Welcome to fixya.com
you have a Rheem Criterion ii Gas Furnace thats not ignighting if you have a digital thermostate make sure batteries are ok. Im now assuming you have the heater door on when your trying to start the furnace ,because there are safety door switches.. if you have the door on .It sounds like the thermostat is bad ,it will start then run for 30 secs and go off...you retry exact same results..goes on for 30 secs goes off...I would say thermostat If it is digital remove it and try to resnap it in 1st. Please Remember to leave me some Positive feedback! Thankyou...
Posted on Dec 17, 2008
Same problem
If I lose power in the middle of a burn it will do as described.
Powering down the furnace and powering it back up fixes it.
Seems like a software issue.
Rheem is hard to deal with.
Posted on Oct 20, 2009
Own rheem criterion. pilot light is on but no hot air
make sure thermostat is calling for heat white & red wire touching to buy pass and verify unit is ok and maybe a bad temp control .
Feb 15, 2015 | Rheem Water Heaters
I just had my furnace cleaned it is a gas rheem. The service guy said it was overheated because of a#3 tube he said the furnace heat exchange is black. What can be do regarding this
I presume you're talking about a gas furnace, even tho the title says Rheem gas water heater. Either way, it works the same for both.
Any black coloring on the heat exchanger is *not* from overheating. Black is from a sooty flame caused by a mis-adjusted burner. (In fact, a sooty flame is less hot). There is an adjustable "air intake plate" for air to enter the burner where the gas enters the burner. A proper flame is made by adjusting this air opening so the proper gas/air mixture feeds into the burner. If the air vent is closed too much it produces a sooty flame.
The age of the furnace is the most important aspect, and that helpful to determine a likely condition of the heat exchanger and burners. Other than a badly adjusted flame, the main thing to watch for is a badly rusted out heat exchanger. But black does not mean rust.
Oct 28, 2014 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
If it is @ the furnace, then it is in the blower compartment on the return side.
Dec 07, 2013 | Water Heaters
"I have a Rheem rheem gas furnace model rcfl-hm4821cc, only a few years old. It was working for several days at beginning of heating season, then abruptly quit. It appears to be trying to cycle through...
If you get no pilot at all, check to see if any gas is getting through the pilot assembly. Try a very long match or butane fire place igniter while it is sparking.
Oct 23, 2013 | Water Heaters
Rheem criterion ii a/c problems
Not a scam but you can get 2 opinions. Moisture removal is a process of closed circuit HVAC. It appears that you have a lot of moisture. IS there a leak in the building structure? Outside air or a swamp cooler can cause this. Sounds like the evaporator coil on the inside unit needs cleaning badly. IT is dropping debris in the pan and causing the flood. The installation of the switches was an attempt to fix the issue by a guessing. I doubt the final diagnosis unless it was a direct result of something the repairman did. He added so many additional switches that it could be his modification that caused the issue.
Jul 16, 2013 | Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
We have a 10 year old Rheem PVW50 Power Vented water heater that works on gas. The last couple of days it has been giving out problems. It will not maintain hot water in the tank. I restarted it and...
The igniter is glowing, but no gas ignites?
So either the gas is entering combustion chamber and not lighting because igniter is positioned incorrectly -or- no gas is entering combustion chamber because air in gas line or bad gas control valve thermostat or gas line is clogged.
When you 'restart' the water heater, somehow you are getting gas to the burner and it is igniting.
I'm not sure what the flame switch is. If the ECO was cut out, the gas control valve would not send power to the igniter and there would be no gas available for 'restart.'
I would adjust location of igniter, check if gas is entering combustion chamber, clean the gas line to the burner, and bleed gas line for air, but another suspect could be the gas control valve thermostat.
Identifying numbers are usually on side of gas valve.
Open following link to help identify gas valve:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jul 02, 2011 | Rheem Water Heaters
The water heater red light keeps flashing rapidly on my Powervent 2 model 41VRP40N. It is not producing hot water and when I read the manual it says it needs more heat. What does this mean. How do I fix...
There are many things to check. The single most important test is for 24V at the gas valve after the ignitor is supposed tp be on. 19 V or less and there is either a bad ground or the ingition control board has failed. (Wire ground problems are a high probablilty)
Here is what the book says:
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Oct 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
6,014 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
