Question about HP PSC 2410 All-In-One InkJet Printer
Hp2400 will scan, copy, fax, but not print from computer any more
Just recently, my computer will no longer recognize I have a printer. It keeps asking me to install one. I can scan from the printer to the computer, but just not print. Can you help me?
  • bountyhun147 Dec 15, 2008
    I have tried numerous times to do as you said. I downloaded the Driver Detect, etc. It seems the loading process goes fine, but at a Rescan, the driver still shows as outdated or not there.
    Genius:
  • 1,011 Answers
Sir,
u need to install the drivers and software for ur printer. if u have already installed try to uninstall and install them...
click this link for drivers
also this
thanks
good luck
Posted on Dec 13, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Dec 17, 2008
    check with manufacturer's website it will be updated one
Not able to print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
THE DOCUMENT WILL SCAN INTO THE SCANNER BUT WILL NOT COMMUNICATE WITH THE COMPUTER HOW CAB I GET IT TO GO TO THE COMPUTER?
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
Sep 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark 2350 will not scan, it will print and copy but not scan. i have had it set up and successfully scan on this computer previously
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/qQJd8g. Select your operating system, download and execute the file.
Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
MX318 fails all fax functions
If you are using only one incoming telephone line, you need tro reset your printer at 'fax priority' position onn your printer. An MX-typr handicap.
Sep 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Dell All in One 926 won't print from Vista
Go to the control panel and select printers.See if it there and set as the default printer.
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Copying/printing--keeps cleaning rather than printing
hi,try disconnecting printer.restarting computer.then reinstall printer.
Mar 04, 2009 | Brother MFC 3420C All-In-One InkJet...
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
HP PSC 2410 All-In-One InkJet Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
