Question about ASUS A8N5X Motherboard
ASUS A8N5X Unresponsive after RAM Upgrade
I just bought 2 Gb of RAM (two 1 Gb, 400Mhz DIMMS) for my A8N5X-based computer, and after getting the RAM installed, the computer doesn't boot. Previously, I had two 512 Mb 400Mhz DIMMS, and it worked fine; however, after taking all the RAM out -- even what was there -- and only putting in one of the new sticks into the A1 or B1 slots, the computer still doesn't boot. I don't see anything on screen, not even the BIOS.
I have no idea what's going on. I don't have a PC speaker to see if I'm getting posts, but the computer works fine with the old RAM. Any ideas?
  • tim5129 Dec 13, 2008
    No dice. The mobo still doesn't boot.
    Not sure if they're unbuffered. I unfortunately bought from a generic site where it's not listed. Don't know if this helps, but the chipset on the ram is Samsung K4H510838B-TCCC:
    http://www.google.com/search?q=Samsung+K...
    President:
  • 1,901 Answers
Just to verify, are you certain the new DIMMS are unbuffered? That MB does not support buffered DIMMS.
If so, try to install the old ones in A1 and B1 and the new ones in A2 and B2. See if it will boot. If so, check your system to see if the total RAM is being "seen". Comment back.
Posted on Dec 13, 2008
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
Hp touchsmart 600 memory upgrade. We have ordered (2) 4 gb memory upgrades for this machine. As far as we can tell the machine only has two slots for memory upgrades and the most recent items sent were (2)...
Maximum RAM supported by this system is 2x4GB PC3-10600 200 pin, DDR3 SO-DIMMs modules.
2x2GB is standard factory RAM. Call back the seller and get a replacement(2x4GB).
Jul 19, 2010 | Computers & Internet
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Upgrade RAM
Max Supported RAM is 3 GB Memory Type DDR SDRAM Supported RAM Speeds 400 MHz · 266 MHz · 333 MHzNumber of Memory Slots 3 x 184 Pin DIMMs
yes, I beleive you can...
Mar 21, 2008 | ASUS A7N8X-X Motherboard
ASUS A8N5X Motherboard Logo
282 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
