Question about HP D1560 Deskjet Printer InkJet
Can I reload ink cartridges for my HP D1560 series printer
I used to reload my HP 500 desket cartridge and I wondered if it is possible to do the same with my new printer
    Novelist:
  • 171 Answers
While new printers usually have special sensors on the cartridge specifically designed to prevent unauthorized refilling, I think you're in luck with the D1560.
From what I've seen it looks like you just have to refill the cartridge through it's fill hole, which is underneith the label. All the refill kits out there do not mention any reset software, so this cartridge probably doesn't have a sensor on it.
Just make sure you get ink that is designed for that cartridge. Ink comes in different viscocities and it's important you get the same kind as what the original cartridge contained.
Posted on Dec 13, 2008
Can i use 21B cartriages in hp deskjet D1560
Cartridge 21 & 21B are similar cartridges, instead of 21 can be replace with21B.. Only difference between them are economy in pricing & yield.. 21B is lesser cost than 21..But both genuine packs are manufactured by HP,
Apr 26, 2012 | HP D1560 Deskjet Printer InkJet
My HP D1560 Deskjet Printer keeps blinking and computer says Cartridge Problems but I have refilled my ink cartridges like I have in the past---what do I do ? It won't let me print ? Ahhh Help
First of all understand what is cartridge the you can solve your problem your self in future if related same: The cartridge contains two parts 1. ink tank, 2. Pen(electronic nozzles controlled by mother board).. Ink tank contains ink & main source to pen to write,.. if ink is over you wont get any image.Ink is there but pen is not writing then no use..both conbination has work to gether to create image..As you said ink is there, but pen is not working due to ecetronic nozzles are faulty & this information with mother board, that's why its indicating that replace the cartrdige..And we can't repair it because of micro technology.
See fig: 1. Container, 2.Nozzles. 3. Electronic contacts to control nozzles..
Just replace the cartridge....
Feb 04, 2012 | HP D1560 Deskjet Printer InkJet
Unable to print due to colour cartridge problem
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 03, 2011 | HP D1560 Deskjet Printer InkJet
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
Can an ink cartridgefrom rapid refill cause printer not to work..printer is hp
Hello.
Sometimes if the cartridge was completely empty then a refill might not work, also there is no way of re-setting the ink levels unless you swap it over 4 times with other cartridges (there is a 3 cartridge memory so on the 4th cartridge change, you can use the 1st one and it will read as new)
Try this link as a way of unblocking print heads and assisting in getting the ink to flow again.
http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards
GM
Jun 22, 2011 | HP Deskjet D1560 InkJet Printer
Light flashes on Deskjet D1560. No paper jam, or queue or cartridge problem
You must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP5610 is not a new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 21, 2011 | HP D1560 Deskjet Printer InkJet
Can I be able to refill the catridges
Drvirao, if you're talking about just refilling the ink cartridge itself, there are refill kits available for purchase, some for a reasonable price. I've provided a link (just copy the entire link below and paste it into your web browser) I know for sure that HP provides Ink Cartridge Refill kits that you can purchase. I hope that this was able to answer your question.
http://www.google.com/search?hl=en&q=ink+cartridge+refill+kits&btnG=Google+Search
Jan 22, 2009 | HP D1560 Deskjet Printer InkJet
HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
HP D1560 Deskjet Printer InkJet Logo
271 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
