Question about JVC TH-C6 System
FINDING THE CORD TO THE SYSTEM FROM THE SPEAKER
WHERE CAN I GET THE CORD THAT CONNECTS THE SPEAKER TO THE SURROUND SOUND SYSTEM, I HAVE LOST OURS AND DON'T KNOW WHAT IT'S CALLED LET ALONE WHERE TO GET IT.
  • Brenda Harris Klein
    Brenda Harris Klein Dec 13, 2008
    I found out what it's called , it is the s-video cable is it needed to hook the system up and how could I tell which one it is?
    Novelist:
  • 171 Answers
From looking at the manual for your surround sound system
http://resources.jvc.com/Resources/00/00/93/GVT0150-001D.pdf
It looks like it just uses the regular spring-loaded clips to hold the speaker wire in place. All you need is regular copper braided speaker wire, nothing fancy. Then you strip about half an inch of insulation off the end of the wires, and pull back the spring loaded clip and put the wires in, then release the clip so it clamps down on the bare metal.
Speaker wire you can get from anywhere that sells the actual systems. I know places like Radio Shack (The Source by Circuit City) sells spools of it. Any other electronics store probably sells it too. It's common stuff.
Posted on Dec 13, 2008
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Switch our tv to souround sound
Surround sound will come from the speakers from your surround system. So if you have it connected through HDMI 1 select that option from the source button on the remote control. If you have it connected through Scart 1 then select AV1 from the source button. It also best to turn the volume from the TV to minimum so that the sound only comes from the surround speakers.
Mar 23, 2009 | LG 47LG50 47 in. LCD HDTV
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Surround sound keeps shuting off
the system go to protect mode in case of trouble in output stage(power output component and cords and speakers.
try to connect each speaker one by one until you find the bad one change cord first for the bad one and check if not working you must change speaker itself.if all above does not solve the problem you must pass your sony to service center
Mar 23, 2008 | Sony HT-DDW700 System
Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Oct 07, 2007 | Televison & Video
JVC TH-C6 System Logo
165 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
