Vs24pr ventless propane heater
Pilot lights then when you turn control to on and remote switch to on flame lights but only stays on for about a minute then clicks and turns off.
It could be safety feature because of too much carbon dioxide in the room.
ventilate the room and you wont have the problem.
Posted on Dec 15, 2008
Propane ventless wall heater pilot light is to big
You have the correct pressure equaliser on the propane bottle giving the correct pressure.
  1. The minimum gas supply pressure must be 1" water column (249 pa) above the manifold pressure printed on the appliance data plate
  2. The maximum gas supply pressure must not exceed 14" water column (3487 pa or 34.9 Millibars)
Feb 10, 2018 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Vs24pr propane heater
i would change thermalcouple which keeps flame lite
Dec 13, 2008 | Heating & Cooling
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
