Question about Philips DVDR755/17 Burner
PHILIPS DVDR 75/17 error code C003 TRAY BLOCKED
When I turn on the machine, I get this error and the tray won't open. Something like C003 tray blocked. I am in the Philippines and the Philips Tech Center here doesn't know anything about this model as it was purchased in the
States about 2002/03. I sure would like to get the tray to open and figure out what's wrong with this. The unit had been in storage for a while while moving/shipping from the States to the Philippines.
Thanks,
Jim Lacy
  • jim_borbonce Dec 14, 2008
    The tray still won't open. Do you have any other suggestions? All help is appreciated. Thanks
    Problem Solver:
  • 6 Answers
Jim, try to open the tray manually open the cover rotate the motor or the belt manually.
Posted on Dec 13, 2008
Dvdr philips tray open
its a tray track or belt problem plz contact your Philips service center
Sep 08, 2011 | Philips Audio Players & Recorders
My Technika DVDr 2005 drawer will not open and has a DVD in place - how can I retrieve the DVD?
turn it off then unplug the dvdr then after a while plug it again and turn on, now press the play button after a while press the stop button then next is the eject button. if still the tray won't eject unplug the dvdr use a philip screw driver unscrew to open the cover. look for the plastic motor gear then manually turn it with your finger to eject the tray now you can get your dvd. place back the cover and plug the unit and then turn on to check if its working again and eject the tray. thanks i hope it will help you good luck.
Jun 13, 2011 | Televison & Video
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Aug 22, 2009 | Philips Televison & Video
My dvdr 3380 is blocked...what can to do?
the rubber belt inside de dvd player to open de tray is broken. I replaced it with a elastiek. you need some technical skills to repair it.
Aug 01, 2009 | Philips DVDR3380/05 DVD Recorder
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Philips DVDR 3370h dvd tray stuck
hi there, if you found solution to problem please e-mail to josepht@eskom.co.za
Mar 08, 2009 | Philips DVDR3370H DVD Recorder/HDD...
Blocked
The solution for this problem is on this forum here http://www.fixya.com/support/t353456-dvd_player
Apr 13, 2008 | Philips DVDR 3355 DVD Recorder
Philips DVDR755/17 Burner Logo
603 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
