Question about HP iPAQ hw6515 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
  • ashishman Dec 30, 2008
    I have same problem with 4GB card
    Problem Solver:
  • 6 Answers
Only some cards are noted as SDHD and some are just SD, newer large cards going SDHD and almost anything over and including 8 is usually SDHD. If you can find an old school SD card which is in the 4gig range it will work in this smartphone. I have used a 4 in mine without issue but I believe it is a limit with the phone that it will only support 4
Posted on Dec 29, 2009
  • 699 Answers
The IPAQ 6515 will only support 'standard' SD cards up to 2GB.
Anything SD card with higher capacity (4GB, 8GB, 16GB) is classified as SDHD (High Density) and cannot be used in older device .
To make it worse, some SD 2GB also behave as SDHD card and will not work on older devices!!!
ps. the above comments apply to both the Full size and mini SD card slot on the IPAQ 6515.
Posted on Dec 19, 2009
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Posted on Dec 13, 2008
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
Your 8 Gig card is a SDHC (HC=High Capacity) Card. All HC cards use a different format, which the 6515 can't use...
The biggest capacity the 6515 can use is 4 gig on the SD and 2 gig on the mini SD.
My 4g Transcend card and 2g Sandisk cards have been faultless for about 2 years now.
Sorry, but the 8 gig card is a wonderfull card, but is useless in a 6515
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq 2400 series will not recognize Compact Flash card
Hello :-) I have a HP Ipaq 4350 and something similar like this happened to me. Except when I tried to take out the SD and put it in again the screen would go different colors and I would have to reset. But sometimes the SD will not get read because of the way you in and outsert  it. Do you push down on the SD card and it will pop automatically or do you pull out the SD card. Because if you pull it out that might be your problem because if you DO pull it out it can damage the metals that read the SD card. Now If you do pull it out  I'd recommend for you to insert the card and then pop it out and reset your device. If you do not pull it out you should go into the finder app on your Ipaq and see if that finder finds you SD card. If it does that means that your program is the problem and that its not fully compatible with your ppc or your specific SD card. Im sorry if this doesn't resolve your problem.
Dec 31, 2007 | HP iPAQ H2210 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
SD card failure...Help!
Have you tried resetting the iPAQ? I would remove the SD card and perform a soft reset (the little hole on the bottom) then re-insert the SD card and see if it detects. Give it a try and let me know what happens.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Hw6515 problems
So there are good reviews of the 6515 over at Dave's Ipaq. Various people have been testing them out and reviewing them. Your questions might get answered more over there? http://davesipaq.com/
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
My ipaq won't open!
if you have inserted SD or other cards and devices in your IPAQ try to stay IPAQ without them.... if ypu don`t have it ---- then go to the service center....
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
Ipaq 6515 & WLAN?
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
