Question about HP iPAQ hw6515 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card
I inserted a new card as above and the IPAQ does not seem to see it.
  • 4 Answers
Your 8 Gig card is a SDHC (HC=High Capacity) Card. All HC cards use a different format, which the 6515 can't use...
The biggest capacity the 6515 can use is 4 gig on the SD and 2 gig on the mini SD.
My 4g Transcend card and 2g Sandisk cards have been faultless for about 2 years now.
Sorry, but the 8 gig card is a wonderfull card, but is useless in a 6515
Posted on Dec 17, 2008
2 Suggested Answers
  • 6 Answers
SOURCE: IPAQ 6515 doesn't recognize new HP 8Gig SD card.
only some cards are noted as SDHD and some are just SD, newer large cards going SDHD and almost anything over and including 8 is usually SDHD. If you can find an old school SD card which is in the 4gig range it will work in this smartphone. I have used a 4 in mine without issue but I believe it is a limit with the phone that it will only support 4
Posted on Dec 29, 2009
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq 2400 series will not recognize Compact Flash card
Hello :-) I have a HP Ipaq 4350 and something similar like this happened to me. Except when I tried to take out the SD and put it in again the screen would go different colors and I would have to reset. But sometimes the SD will not get read because of the way you in and outsert  it. Do you push down on the SD card and it will pop automatically or do you pull out the SD card. Because if you pull it out that might be your problem because if you DO pull it out it can damage the metals that read the SD card. Now If you do pull it out  I'd recommend for you to insert the card and then pop it out and reset your device. If you do not pull it out you should go into the finder app on your Ipaq and see if that finder finds you SD card. If it does that means that your program is the problem and that its not fully compatible with your ppc or your specific SD card. Im sorry if this doesn't resolve your problem.
Dec 31, 2007 | HP iPAQ H2210 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Red light!!!!
You have the red-light of death.
This is caused by a dodgy microswitch.
There is full fix instructions for Ipaq 6515 here :
http://www.123datarecovery.co.uk/fix_ipaq_6515_6915.htm
As for your memory card, if it's still blank when you use your Ipaq thru the USB, you can easily recover using a program. I forget the name of the program I used, but it basically recovers the FAT.
You might not be able to read the memory card except in the Ipaq BTW, so try to fire up the Ipaq first.
Dec 26, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 gps issues
Hello, You may need to go get the update to 5.21 .. heres the link .. http://www.tomtom.com/support/category.php?ID=3&Language=4&FID=3370 Install it and that will help Bob
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 & WLAN?
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
311 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
