Question about Canon imagePROGRAF iPF8000 Printer
Canon ipf8000 won't cut paper
We have a canon ipf8000 that has stop cutting the paper, which means having to reload the paper everytime, anyone know how to solve this???
  • basilis
    basilis May 16, 2017
    i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- for questions and support
  • 3 Answers
Check to see if the cutter module has fallen off the print heaqd carriage. A common problem. It is a blue module that snaps into the left side of the carriage. Usually if it has fallen out, it can be found in the far left end of the printer, so you have to stop the printer, lift the lid and stick your hand into the left cave.
Posted on Dec 29, 2008
  • Raderdc Apr 17, 2012
    Also had to refer to how to get to service mode on another fixya Post to replace cutter and get the printhead out.
Posted on Nov 05, 2012
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
I have a Canon iPF8000 large format printer and a message comes up saying, "Clean Right P Head". I have cleaned the printhead as it states, but it keeps on showing on the printer screen. Because of this,...
Canon has bad heads for this LFP, it is not unusuall. Every model has this issue, canon even lower the price of head because of this.
When you replace the print head message disapears for some period of time.If Im not wrong I think that is P-01 or 03 print head involved.
Jun 15, 2010 | Canon imagePROGRAF iPF8000 Printer
Won't cut on
Hard Disk Drive failure. Needs hard drive and System Software to be reloaded.
May 20, 2010 | Canon imageRUNNER C3200 Copier
Canon IPF 710 with error code E161-403E, abnormally high printhead temperature how do I clear/remedy it?
The error apeared when i stated to print !
How to solve it.
It is about 6 month since we started to use your product.
Apr 22, 2010 | Canon imagePROGRAF iPF8000 Printer
I have a Canon P23-DHV calculator and I cannot remember how to load the paper into it. I tried to read some of the solutions but could not ger any of them to open so I could actually see the solutions
  1. cut the paper/tape cleanly on a slight diagonal
  2. hang the paper/tape so it comes from under the roll
  3. insert the fresh cut into the slot on the back (between the power plug and tape roll holder)
  4. press the FEED button to advance the paper.
Now, does anyone know how to turn off this blasted auto-shut-off feature????
Jan 24, 2009 | Canon P23-DHV Calculator
Cant switch frome landscape to portrait (ipf8000)
try to use the conserve paper option in page set up tab.
Aug 04, 2008 | Canon imagePROGRAF iPF8000 Printer
Lead edge detect error
first check the green led on the panel (feeder selection) normally for cut sheet must be on the right side and for roll on the left side.
Jul 30, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon ipf8000s can not cat the paper also gives hardware error 03800500-2f2f
Check your cutting wheel is in properly, have had a similar problem on a IPF8100, sometimes the wheel/cartridge just pops out
Jul 24, 2008 | Canon Office Equipment & Supplies
Cuts a strip of paper every time it is turned on
1st solution: if your paper is plain then you can say to printer that is coated, but with this solution you'll spend more ink.
2nd solution: go to paper detail menu and find the trim edge (if i remember well) and change it to off or no.
Jul 04, 2008 | Canon iPF700 InkJet Printer
Canon imagePROGRAF  iPF8000 Printer Logo
1,362 people viewed this question
old marine
old marine
