Question about Jenn-Air JDB9910 Dishwasher
Maytag dishwasher nozzles clogged on water spray spinning devices
I have a Maytag MDBD820 dishwasher and need to take apart the lower and upper water spinning nozzle jet device as many of the nozzle are plugged and neither will spin. I do not know how to unscrew or disconnect the assembly and it is all plastic so I don't want to break the connections. It looks like the center plastic part will unscrew but maybe it is left hand threaded?
The manual is no help.
Dishwashing by hand is pretty tedious.
  • Anonymous Jan 11, 2009
    Amazing - I have the same problem which started about a week after this post. Hope someone can help.
5 Suggested Answers
  • 2651 Answers
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
Posted on Mar 15, 2008
  • 136 Answers
SOURCE: Maytag Dishwasher 2004 Jet Clean
go to the maytag website and they should have a list of codes under troubleshooting if not call maytag repairs
Posted on Oct 30, 2008
  • 9 Answers
SOURCE: How to remove lower spray arm and center plate cover?
You can lift the center cover plate up about 3/4 inch and check it out with a flash light before going through the trouble removing everything. Most likely all the foil can be removed this way. The rest is gone down the drain.
Posted on Nov 20, 2008
  • 82 Answers
SOURCE: Dishes are not getting cleaned
Hello kharyespy,
First we have to address the obvious. Are you making sure that there aren't any large spoons sticking up from the silverware basket. Are there any objects hanging down from the top, or from any where in the bottom.
Are the holes in the ends of the spray arm clogged. If they are, these are the ones that cause the arm to spin.
If all of this checks out, there are some dishwashers that have whats called an invertervalve which sends water to the bottom spray arem then the top, and alternates like that through out the cycle. They do this so that there is extra water pressure going to the individual arms. This valve may be stuck so that it is only sending water to the bottom. Sometimes they get stuck right in the middle and lower the pressure to both arms.
You may also have poor water pressure due to a week circulation pump or an obstruction in one of the water lines in you unit.
If you find the problem and you want to get rid of the cloudiness, you can run about a cup or two of white distilled vinegar through the unit with the glasses in it. This can be kind of tricky though, as you need to make sure that you put it in the bottom of it when it is sloshing around and not right before it drains. If you don't want to deal with that then you can buy what is called "Glisten" dishwasher cleaner, which can sometimes be found at the grocery store, or you can also use "Tang" orange drink. Just fill up both of the soap dispensers and let it go through the cycle.
Also I have found that powdered detergent works better than liquid. Over time it causes a film in the entire tub and also clogs the spray arms.
Well that is all I can think of right now. Hope this helps.
Posted on Dec 03, 2008
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Oct 25, 2015 | Indesit Dishwashers
The upper rack will not clean the dishes the lower one work ok
Check for dirt in your spray nozzles. If they get too clogged, the nozzles won't spray water and the spray head won't turn or will turn too slow.
Dec 17, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Jan 30, 2009 | Maytag MDBE790 Built-in Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Dec 22, 2008 | Maytag Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Dec 29, 2007 | Kenmore 15952 Dishwasher
Jenn-Air JDB9910 Dishwasher Logo
465 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
