Question about Jensen CD-1400R Cassette/CD Boombox
Setting Clock & presets
I lost my manual and don't remember how to set the clock. Also I have several FM stations I would like to put in the presets but again don't remember how.
0 characters
1 Points
The memory settings are lost at switched off.
Many portable radios require batteries that keep clock and oher functions - including memory presets. Without knowing the brand and model of your radio I can't get into any more detail than that. Look for a battery door or the manual online with google.
Oct 15, 2015 | Boomboxes
Clock setting
Get into this site. you can download the user manual to your ILive from here. You can get details about how to set clock from this user manual. If you feel any difficulty in downloading the manual, contact me by Fixya comment box. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 20, 2012 | Boomboxes
How do you auto preset radio stations?
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
How to program radio presets on sony cfd-s01
hold down the display/enter button until FM - 01 flashes. then press the display/enter button. The station you were tuned into is now preset #1
Dec 29, 2008 | Boomboxes
Resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
Oct 11, 2008 | Aiwa CA-DW235 Boombox
Jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Sep 17, 2008 | JVC RV-DP100 Cassette/CD Boombox
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
2 Press 4 or ¢ to adjust
the hour, then press
The minute digits start flashing on the
3 Press 4 or ¢ to adjust
the minute, then press
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
How do I set the clock and preset stations.
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
Apr 10, 2007 | JVC RC-QN2 Cassette/CD Boombox
Jensen CD-1400R Cassette/CD Boombox Logo
20 people viewed this question
Top Jensen Boomboxes Experts
Are you a Jensen Boombox Expert? Answer questions, earn points and help others
