PC is not reading Cavalry external HDD anymore.
I think I may have a problem. I bought an external harddrive off New Egg the other day and I was able to use it. My friend and I put about 8 gb of stuff on it. It is a 250 gig HDD. I tried deleting the partition, repartitioning it, and formatting it. When I try to format it, it wont format. I look in the Drive Manager and there is not a file system, what else can I do?
  • john879 Dec 15, 2008
    If you read my post all the way you would see that I already tried that. I will send it back as soon as I can.
  • 94 Answers
Right click 'my computer'
click 'manage'
in the new window that appears look down the left side and you will see an entry called 'storage' the 3rd entry under this should be 'disk management' click on this
you should now see all the drives installed on the computer, choose the one you need and right click on it, then choose 'format' from the drop down list. follow any instructions.
If it does not format, then it could be a faulty drive, in which case return it to where you bought it.
Posted on Dec 13, 2008
Unable to read external HDD after plugging it to a Mac (previously it is readable via a Windows PC)
Chances are it was formatted as NTFS format by the PC which is not MAC compatible. You will need to reformat the drive in HFS format if you want it to work as a MAC disk only or in FAT32 format if you want to read it in PC and MAC machines.
Jul 24, 2014 | Western Digital WDG1C2500N MyBook Premium...
External harddrive not detected
if you think your HDD is broken take it out of the caddy and place in your PC if the new HDD pops up in my computer than your drive is fine simple buy a new caddy install and carry on
Jan 08, 2014 | Transcend Computers & Internet
My Cavalry 1TB hard drive stopped working the 3rd day after i bought it. It powers on, you can hear it working, but the computer won't recognize it. I can't initialize it through Diskpart or Disk...
The HDD is probably in working condition, however the enclosure may be damaged. You can remove the hdd inside the cavalry storage enclosure, and if you have a desktop install it in the desktop to get your data off of it. You may instead wish to purchase a new hdd enclosure which can be bought online from many websites such as or
May 11, 2011 | Cavalry Storage CAUM3701T0 1 TB USB 2.0...
My external harddrive fell and its not working. Is there any way this can fix or am i going to have to buy a new one? thanks
Inside this External HardDrive is I believe a Internal Laptop HardDrive. On You Tube there are videos of how to dismantle it, just type the name in You Tube and if you get leads you should be able to connect it inside a P.C. and retrieve yours important files.
If the connections are the same as an Internal P.C. HardDrive your in luck.
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... Thread can be found in 'Technical' under 'General Technical Issues'
Aug 23, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
USB not reading in computer
try a new cable, and a different usb hub or a different pc, if not found, drive is bad
Apr 13, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
I have been using my external usb harddrive for recording (seagate freeagent pro) its been working fine for about a month but earlyer it just stopped, the power light went out and i havent been able to get...
External HDD are similar to the normal internal HDD, only difference is that The physical harddrive is only place into the casing with usb terminal port so you can remove the physical HDD. Your casing's usb terminal may be damaged. Borrow a casing for a external usb HDD from a friend that is working and use it to extract your data to a PC. Hope it helps.
Nov 11, 2008 | Computers & Internet
Need help recovering from a Steel Vine software mistake
well..maybe, and that is a major maybe..sometimes, with really good tools, some of that can be recovered, like when a hard drive crashes. assuming there was no other backup, this is problematic. I recommend you seek a really top flight computer person. This will cost a bundle though.
Oct 22, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
HDD won't work anymore.
Just change ( buy ) new external then put hdd on new external and everything will work fine!
Feb 27, 2008 | ACP Cavalry (CAUE37500) 500 GB USB 2.0...
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
Feb 12, 2008 | Cavalry Storage Cavalry CAUO37500 500GB...
PC stopped reading Cavalry External HardDrive
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Dec 02, 2007 | Western Digital Caviar WD200BB 20 GB Hard...
Computers & Internet Logo
David Payne
David Payne
