Question about Polaroid FLM-2011 Television
Polaroid flm 2017 turns on then goes black sound still works
Polaroid flm 2017 two years old . turns on with perfect picture for about 2 seconds. then goes completely black. the sound and chanel changing is still working, just a black screen. turn it off and back on and the same thing happens over and over. someone said it was a capasitor for 4 bucks from radio shack. could i be this lucky?
  • Anonymous Mar 02, 2009
    same turn on then the screen goes black , some times there is sound ,also green light on power box goes dim or flashes any help please
    Problem Solver:
  • 6 Answers
This problem is often replated to a leaking power supply capacitor on the secondary side of psu rated at +/- 2000uf at 12v...yup 4 bucks should do it...the hardest part is often opening the power supply up screws are often located underneath rubber feet....never make contact with the primary ac supply side even after it is unplugged reservoir capacitor high voltage can store a charge for long time and be dangerous to contact.
Posted on Aug 01, 2009
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Polaroid FLM-3732 Television turns on then off
A common problem with this television is the power unit. Some of the capacitors go out on them within 2 years. You can buy a replacement power unit for about $150 or if you know how to use a soldering gun you can purchase the capacitors for about $5 and fix the unit yourself.
I just fixed my Polaroid 3732 and it cost me $3.49. I would push the power button and the standby light would come on but the picture would not appear. After I changed the capacitors it starts right up.
May 02, 2010 | Polaroid FLM-3732 Television
POWERS UP BUT NO PICTURE OR SOUND WILL NOT SHUT OFF POLAROID 37" HD LCD TV-2 YEARS OLD
my POlaroid 37" did same thing blue light stayed on no pic or sound was 2 electrolytic caps on power supply board took back off and they were noticably bulged at top radio shack sells these caps at $3 apiece fixed mine works like new saw a video on here how to do it
Dec 07, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Artifacting pixels w/ over the air antennae
Most of the time the audio sound output is bad
Jan 29, 2009 | Polaroid FLM-3232 Television
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid LCD TV 37" Black screen
I had the same problem. But found the fix on this website!!
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-3732 Television
Flm-3201
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Aug 03, 2008 | Polaroid FLM-3201 Television
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Nov 19, 2007 | Polaroid FLM-2632 Television
Polaroid FLM-2011 Television Logo
225 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
