Question about Samsung SGH-e315
Service Light Will Not Turn Off!!
My phone was in my pocket for about two hours and when I next looked at it, the service light on the front stayed on. It had been like this for about two days now that the light will not turn off! The light is on even when I turn off my phone. I tried removing the battery a few times and then turning the phone back on again and it still stays the same. Even if the batter is not attached to the phone, it the phone is attached to the charger the light stays on. I wouldn't mind so much except I like that the light alerts me to any missed calls or texts, and I think this problem will drain my batter faster. HELP!!
    Brigadier General:
  • 7,752 Answers
Have the phone check by a mobile tech or type *2767*3855#
Posted on Aug 17, 2008
SOURCE:
FRONT PARKING LIGHTS STAY ON WITH KEY OUT OF VEHICLE
What make vehicle do you have Mark , it could make a difference ! Some vehicles have lighting control modules that short internally keeping the lights on , others have relays that the contacts say closed keeping the lights on. You could look at a wiring diagram an see what all is involved in that circuit ,what controls those lights ! Go to www.bbbind.com there are free wiring diagrams an TSB'S - technical service bulletins . On the home page click on Technical Information - next page click on - All TSB's and diagrams for every make and model - FREE - next page go to the bottom of the page an click on I agree . Next page click on wiring diagrams , then enter your vehicle information .Next under system click lighting , then under subsystem click parking lamps . Good luck Mark , hope this helps !
Jun 30, 2015 | Cars & Trucks
How can I determine with certainty the cause of a Service Engine Soon light?
Personally I would do a complete engine service, for example Air and Oil filters, Oil and Plugs (it may also be worth changing the coolant as I am not certain of the parameters that are monitored by the system) If the light still remains on then the most likely problem is the Engine Managment Unit or a sensor.
Nov 28, 2011 | 2004 Cadillac Deville
"Service" light just started coming on over the weekend. It comes on, stays on for about 5-10 minutes, then goes off. The other lights - check engine (I think), oil, etc. - come on when I turn on the car...
The light is set to light by milage and it is to let you know that the next service is due. This is reset by removing the rubber grommet that is to the left lower corner of the speedometer and depress the reset button.
Oct 25, 2010 | 1991 Volvo 740
Service engine light is on want to turn it off
WELL IF SERVICE ENGINE LIGHT IS ON YOU HAVE A FAULT IN ONE OF THE SENSORS.YOU NEED TO SCAN CAR WITH CODE SCANNER SO YOU CAN FIX THE FAULTY SENSOR.THEN ERASE CODE.IF YOU DONT FIX THE PROBLEM THE SERVICE ENGINE LIGHT WILL STAY ON.
Jul 18, 2010 | 2002 Oldsmobile Alero
Service engen light comes on and will not go out
What has happened is that the engine computer has seen an emission or operational problem of a nature that causes it to turn on the "service engine" light. The light will stay on, in most cases, until the problem has been repaired and the service code has been erased. There are a few instances where the light will turn off if the computer doesn't see the problem for several drive cycles but in the majority of instances the problem doesn't go away and the light stays on. You should have the vehicle hooked up to a scan tool at a service facility so the service codes can be read and a diagnosis can be made of what the problem is. There are multiple items and reasons that can cause the light to come on and really no way to know why it is on until the codes are looked at.
Jun 15, 2010 | 2006 Chrysler Town & Country
Hey when I turn on my phone, It stays a blank screen and the light at the back and front don't turn off. It doesnt load.
this sounds like a software issue, you may be able to have the device reflashed at a service and repair center
Apr 04, 2010 | Sony Ericsson K850i Mobile Phone
Service in and out...phone shuts off automatically
It may be the problem related to Network IC....
Dec 15, 2008 | Motorola Mobility RAZR V3
2004 Cavalier, Service light, ABS light, Trac Off light
It is the wheel speed sensor jumper harness more than likely on the driver side. They replaced the orginal with a newer better one but never issued a recall.
Jul 11, 2008 | 2004 Chevrolet Cavalier
WARNING LIGHT ON FRONT OF TV
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent.
Jul 02, 2008 | LG RE-44SZ21RD 44" Analog Television
Samsung SGH-e315 Logo
114 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
