I keep getting error message wrong cartridge on my canon image class mp700 printer. I have taken the cartridges out and the message is still flashing. Have uninstalled the soft ware and reinstalled it. Also uninstalled the printer and reinstalled it. Still get the same message.
Comments:
Dec 13, 2008
- They are genuine canon cartridges that i have been refilling for 5 years.
Is the cartridge you are using genuine canon or a refill?
Gremlin11
Same Problem
Apr 10, 2009
-   I keep getting error message wrong cartridge on my canon image class mp700 printer. I have taken the cartridges out and the message is still flashing. Have uninstalled the soft ware and reinstalled it. Also uninstalled the printer and reinstalled it. Still get the same message.. i have unpluged and turnd off and turned it back on .. i have followed everything it has said and nothing i am doing is fixing the problem ....
What do i do ???? -   Guest
Mar 02, 2009
-   Aha! but I have always used hp cartridges in my HP700 and today I have this "wrong cartridge" message. I have just replaced with all new hp cartridges! same old thing!-   vonza
Jan 02, 2009
-   I have the same problem - error message saying that I have the wrong cartridge - but in my case when I open the cover the set of ink cartridges will not glide over into the usual position where you could access/replace the individual cartridges. So now I have no way of checking the cartridges .
-   lancewk
There in is the problem, these cartridges are not made to be refilled. You are lucky to have got away with this for this long. The most likely scenario is that your printhead has now failed which is why it will not recognise your cartridge.
The first thing you might try is to go out and buy a new cartridge. If this fails, then you will need to replace the print head. In this case, you would be better off calling it quits and getting yourself a new printer.
I am sorry if this is not all that you want to hear, but that is the facts and I would be doing you an injustice to tell you otherwise.
its not a true fix but I had the same issue. I turned off printer and slightly moved the paper thickness lever over a few inches. I turned it back on and the cartridge error was off. I do get a pop up from my printer program on the computer every time I initiate a print job asking to correct the lever, I click OK and it prints. I know its aRube Goldberg fix but I need this printer every day for work and for now it works.
Canon MultiPASS MP700 printer prints blank page. Have installed working printhead from another...
(More)
Canon MultiPASS MP700 printer prints blank page. Have installed working printhead from another printer and still will not print. Took unit apart and cleaned waste ink pads. No print. Seems to be going through the cleaning cycle okay. Is there some way the logic board is not sending correct signals to printhead? Am stumped as to what to do next.
Printer stopped printing, ink was fading, replaced cartridge with brand new Canon 3E BK but now have...
(More)
Printer stopped printing, ink was fading, replaced cartridge with brand new Canon 3E BK but now have no printing occuring. Lynn@ocwhite.com
