Question about Canon imageCLASS D761 Copier
Paper jam in the fuser unit.
I'm a copier/printer tech, but have no experience on the Canon ImageClass D761. How can I get fiser out?
  • 76 Answers
Hi
first you must remove the side panel on fixing side and move the scanner unit to reveal a two hole at the top of the machine,total of 3 screw for fixing unit,and one of that screw in front side of fixing unit you must use small philips screw,and take care to remove the wire
Posted on Dec 13, 2008
My cannon D760 quit working. It flashes E000
if you are able to repair it.then look for paper jam in the fuser unit.E000 is related to fuser section
Jan 15, 2011 | Canon imageCLASS D761 Copier
System error 000
A E000 means that the fuser unit is not heating up correctly. You will most likey need a new fuser unit. If you unplug the copier and plug it back in and it will not come to "Ready" you need a new fuser. Good Luck
Jul 23, 2010 | Canon imageCLASS D761 Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Solucionar el error de systema E000 en mi fotocopiadora imageCLASS D761
Problem on Fuser unite.
Please check fuser lamp or fuser fuser cover.Check power supply heater fuse.May be problem two things.
Jan 25, 2010 | Canon imageCLASS D761 Copier
Paper jam Cannon PC 1060
hello,remove all covers arond the exit area lift cart door, control panel screw ,slide left,remove glass.holes in top under glass and under control panel,slide top to left,look down into holes to see screws holding fuser in.three connectors slide out exit side ,carefully dissasemble fuser to remove jam.i replace at least one unit a week.do use sharp objects
Nov 03, 2009 | Canon imageCLASS D761 Copier
Ghost printing
Hi for ghost printing basically it is
1)fuser roller surface wear n tear
2)check any fragment of paper stuck at the fuser unit.
3)fuser unit is located near the printing output.
Sep 05, 2009 | Canon imageCLASS D761 Copier
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
Paper jams right before it exits copier
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Feb 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jamb
you need a copier tech to fix it the fuser unit has to be removed to get jam out i done a lot of them and when some people try as you have to remove the jam they do more damage
Aug 20, 2008 | Canon imageCLASS D761 Copier
Printer/copier is spitting out pieces of thin plastic film/tan on one side and dark grey on the other. Paper is jamming and discoloration on one side of the sheets all the way down.
If it is clear thin plastic like saran wrap, then that is probably the fuser roller sleeve.
The only way to repair that is replacing the rollers or fuser unit.
That would be a cause for the jamming also.
Replacing the fuser unit or the fuser rollers will probably require a service technician to come in to replace these parts.
Most copier companies do not make the fuser unit customer replaceable except for a very few makes and models.
Sorry I couldnt give you some more information.
I hope this information still helped you a bit.
Good luck.
Mac =)
Mar 29, 2008 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Copier Logo
329 people viewed this question
old marine
old marine
