Question about Baumatic 18 in. BDW45.1 Built-in Dishwasher
High pitched whining noise from bottom of dishwasher
I have had a Baumatic BDW for about 2 years now. A few months ago it started to make a whining noise when operating. It seems to be coming from the bottom arm, possible the motor that turns it. Not sure if something might have got stuck or if the motor is making the noise. Any advice would be greatly appreciated, as the noise is getting pretty annoying! Scott.
  • Anonymous Mar 18, 2014
    bottom arm wont spin & makes an awful whining noise
    President:
  • 1,462 Answers
The arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Posted on Apr 03, 2007
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Squealing noise
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Here is Manual onlineManual online
Nov 04, 2013 | Baumatic Dishwashers
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Sometimes goes ''clunk'' when coming to a stop,then makes noise like a chain being dragged over a pipe in 1st gear.Noise stops after a few minutes.Has a low pitched whine in OD,sometimes accompanied by a...
Maybe a stretched transfer case chain.
I wouldn't rule out some trans issues
Got the correct fluid in transfer or proper level
The clunk sounds like ,U-joints
Check all the mounts on everything,trans, transfer.etc
May 03, 2010 | 2001 Chevrolet Silverado 1500
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
596 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
