Question about Recoton Advent Advent Q2035A 20" TV
TV shuts off after i press input button
When i turn on my tv there is no picture at all and there is like a barcode streak in the bottom of the screen and after a while it shuts off on its own. Also when i press the input button it shuts the tv off automatically. Any suggestions?
Thank You. Do u know how I can solve this problem on my own?
Posted on Dec 13, 2008
  • 790 Answers
Hi
you have defective power oscillation in Hot area, and you have defective vertical output change the vertical output...
Thanks!
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Tv works jsut no pic black and white screen says weak or no signel?
    If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
    To find the the correct video input:
    1. turn On the device you are trying to see
    2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
    You program the TV by accessing it in the User Menu.
    Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
    Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
    Viewing mode will only go from zoom to wide!!!! please help
    Hi!
    Found some relevant info on how to adjust your video settings... You might want to give it a try!
    Thanks! =)
    4.12 PC Input Picture Adjustment
    The Picture Adjust menu operates in the same
    way for the PC Input as for the DTV / TV input in
    section 4.2 for Backlight, Contrast, Brightness and
    Color Temperature.
    4.12.1 Auto Adjust
    When the MENU button is pressed, the On Screen
    Display (OSD) appears on the PICTURE ADJUST
    page. Press the button to highlight the Auto
    Adjust selection.
    Press the button for the LCD HDTV to adjust to
    the PC signal timing automatically.
    4.12.2 H-SIZE
    Press the button to highlight the H-Size selection.
    Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
    the horizontal size.
    4.12.3 Horizontal Shift
    Press the button to highlight the Horizontal Shift selection.
    Press the button to start adjusting the horizontal position of the picture. Use the or button to
    adjust the horizontal position.
    4.12.4 Vertical Shift
    Press the button to highlight the Vertical Shift selection.
    Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
    the vertical position.
    4.12.5 Fine Tune
    Press the button to highlight the Fine Tune selection.
    Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
    4.14.1 Understanding Viewing Features
    Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
    You can switch viewing modes using the remote control.
    4.14.2 Viewing Modes
    Normal Mode
    The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
    added to the left and right of the display image. Standard TV broadcasts are
    displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
    to as pan-and-scan or full frame. These movies were originally filmed in 16:9
    (widescreen), and then modified to fit a traditional TV screen (4:3).
    Wide Mode
    When watching a standard broadcast or full-frame movie in this mode,
    the display image is stretched proportionately to fill the TV screen.
    When watching a widescreen (1.78:1 source) program or movie, the
    display image fills the TV screen. If you are watching a widescreen
    (1.85:1 or 2.35:1 source) program or movie, there will still be black
    bars at the top and bottom.
    Zoom Mode
    When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
    program or movie, the display image is zoomed proportionally to fill the
    width of the screen. The top and bottom are cut off to remove most of
    the source material’s black bars. This mode is good for programs or
    movies with sub-titles.
    Panoramic Mode
    When watching a standard broadcast or full frame movie in this mode,
    the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
    horizontally on the left and right sides to fill the TV screen. The center
    of the image is not stretched.
    Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
    mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
    will return to widescreen.
    Jan 04, 2009 | Televison & Video
    Picture has a blue shadow
    Seems convergence out IC is fried in TV so it gives blue shadow.
    Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
    Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
    Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
    Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
    Dec 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
    RGB
    Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
    Dec 23, 2007 | Vizio L37 Television
    Mitsubishi tv
    I found this online somewhere and it cleared my problem.
    (my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
    MITSUBISHI CS3114R
    Parental Lock
    This system can lock each channel or different channels on ANT A and ANT B
    as well as locking each of the EXT inputs, so you should confirm what is
    locked before trying to unlock.
    1 On the remote, set the TV/VCR switch to the TV position
    Or . Depending on which remote is being used
    Press the TV mode button at the top.
    2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
    buttons check each channel and input to establish which channels and inputs
    are locked. The screen will tell you if the channel or input is locked.
    3. Press the button labeled MENU. The screen will show the main TV menu.
    4. Press the #5 button (channel lock option).
    The screen will change to show the channel lock System Menu. This screen
    will indicate that the lock system is either ON or OFF.
    IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
    OR:
    IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
    5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
    ask for the code number. Press the #9 and QV buttons at the same time.
    Notes: The screen will change to show an information display that will show
    the selected antenna and channel or input. The display is superimposed over
    the picture. This display will indicate that the channel or input is either
    locked or unlocked. In the lower middle will be instructions to use the
    10-key pad or SCAN buttons to select the desired channels (or the INPUT
    button to change antennas or select the EXT inputs). At the bottom of the
    screen will be instructions on how to change the current LOCK status (if
    unlocked use the ENTER button to lock, or if locked use the CANCEL button to
    unlock).
    NOW GO TO STEP #6.
    5a. Press the #1 button (channel lock ON option). The screen will ask for a
    code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
    and then press the ENTER button.
    unlock).
    NOW GO TO STEP #6.
    6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
    locked, or, use the INPUT button to select the external inputs that are
    locked.
    7. At each locked channel or input press the CANCEL button.
    The screen will indicate that the channel or input is either locked or
    unlocked.
    8. When all of the channels and/or inputs are unlocked, press the MENU
    button again. TV main menu will be displayed.
    9. Press the #5 button (CHANNEL LOCK option).
    10. Press the #2 button (channel lock OFF option). The screen will now ask
    for a code number again.
    11. Press the #9 and QV buttons at the same time. The screen will return
    to the CHANNEL LOCK MENU and indicate that the lock is OFF
    12. Press the MENU button twice to return to normal viewing.
    The parental lock is now entirely cancelled.
    Bob Waterman, CET® #RI-28
    Master Technician License #9109
    Service Manager / Parts Manager
    Gemini Computer, TV, & Security Alarms
    (508)695-7302
    (508)695-7769 FAX
    geminitv@xxxxxxxxxxxxxxxx
    geminitv@xxxxxxx
    www.geminicomputertvsecurityalarms.com
    Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
    Mitsubishi tv
    Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
    Oct 16, 2007 | Televison & Video
    Recoton Advent Advent Q2035A 20" TV Logo
    55 people viewed this question
    Top Recoton Advent Televison & Video Experts
    S. Gontko
    Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
