Question about HP OfficeJet 6110 All-In-One InkJet Printer
Remove and check cartridge
My printer keeps saying to remove and check cartridge. My cartridge is new. I was told to reset it. Nothing has changed. Someone please help!
Patrich
Mine says the same. What shall I do?
Posted on Dec 14, 2008
    Scholar:
  • 78 Answers
Gotchababy22.
Your problem is very comon, believe it or not. The problem is not with you, your software or the new cartridges. The problem as I have experienced it in the past is the printer. If you open your printer up and remove the cartridge, you will see where thecartridge is installed in the carriage unit, a white tape with a number of contact points on it. You will also see a flat sping that that holds the cartridge in place. What I have found in the past is that the spring will put a very small hole in the contact tape and damage it to the point where is will not recognise the cartridge. You will need a torch and a magnifying gass to find it usually.
The long and the short of it is that the unit is damaged and there is nothing that can be done as HP do not provide replacement parts for their inkjet range of printers. This tiny hole basically renders the unit as throw away. Rediculouse as it migh sound, it is the unfortunate truth.
Gremlin11
Posted on Dec 13, 2008
Black ink not working, replace cartridge still nothing hp6500 wireless
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
REMOVE THE OLD 2. LEAVE COVER OPEN AND REMOVE THE PROTECTIVE COVER ON THE NEW REPLACEMENT 3. INSERT THE NEW INTO THE SAME CARTRIDGE INSERT AREA 4. RESET YOUR PC TO NEW CARTRIDGE INSERTED 5. YOU WILL BE PROMPTED BY YOUR SYSTEM TO INDICATE IF A NEW CARTRIDGE HAS BEEN INSERTED 6. NOTE THE COST OF THIS TYPE OF PRINTER (MAINTENANCE) IS MUCH HIGHER THAN THAT OF THE LLASER PRINTER
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
My hp psc 2410 keeps reading to remove and check black catridge i clean the contacts, i make reset but nothing. keep saying the same to remove and check black catridge
You could remove both cartridges.
Close cover and turn off printer.
Unplug printer for at least 10 minutes before plugging back into the outlet
Turn on printer and install cartridges.
If this does not correct the problem, the cartridge may be bad.
Dec 25, 2010 | HP PSC 2410 All-In-One InkJet Printer
Says remove and check cartridge on right I've done this and nothing changes!
I have the same problem. If you have a clue what to do, please let me know as well. I have done all of the remove and insert things. I have cleaned both cartridge and nozels. But nothing new is happening.
Aug 20, 2010 | HP PhotoSmart C4180 All-in-One Color...
Inserted new printer cartridges but printer still says"remove and check cartridges" help!!
after any maintenance the printer need to be told that the cartridge has been filled in order to do this you need to reset the error count messages
push power button & resume button together then push the resume twice before i release them together..the result is the blink light stop
hope this helps
Robb
Apr 26, 2010 | HP PSC 2175 All-In-One InkJet Printer
Printer keeps saying remove cartridge on the right
i have this problem to.. will try to reset it and resend
Mar 29, 2010 | HP PhotoSmart C4180 All-in-One Color...
I have a C6280 Printer, I changed some ink cartridges that were low and keep getting a message saying that one of the cartridges I changed is empty. I have tried several new cartridges with the same...
first check before inserting the cartridge.remove the protective tape from the printer .clean the electrical contacts on the cartridge as well as the electrical contacts in the printer with a lynt free cloth.if that does not work try to do a semifull reset
press the red eye removal and print photo simultaneously.then red eye, print photo,red eye. then u will get a service menu . use the down arrow button go to reset menu.do a semifull reset.turn off the printer . again turn it on . if that does not work u need to repair the printer
Sep 12, 2009 | HP Photosmart C6280 Printer
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
