Question about Frigidaire PLEF398AC Electric Kitchen Range
RANGE WONT STOP BEEPING
I AM SERVICEING A FRIGIDAIRE RANGE M#PLEFM399DCB. IVE ALREADY REPLACED THE CLOCK ASSEMBLY AND THE POWER SUPPLY/RELAY BOARDS. I GET ERROR CODES F7,F20,F22.THE PREVIOUS SEVICEMAN BEFORE THAT CAME OUT TO FIX ANOTHER PROBLEM WHILE UNIT WAS STILL UNDER WARRANTY TOOK THE TECH SHEET WITH HIM AND FRIGIDAIRE SAID THEY CANT SUPPLY ANOTHER. THE PROBLEM SEEMS TO BE INTERMITTANT. THE LONGEST TIME THE UNIT WENT WITHOUT BEEPING WAS APPROX 48 HRS AT THANKSGIVING. IS IT POSSIBLE THAT IVE GOT A OVEN TEMP PROBE WITH AN INTERMITTANT PROBLEM? IVE BEEN SERVICEING APPLIANCES FOR ALMOST 30 YEARS, BUT IM REALY PULLING MY HAIR OUT ON THIS ONE.
szwaan
  • 209 Answers
SOURCE: frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Posted on Jan 20, 2008
ngfam1
  • 639 Answers
SOURCE: frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
SOURCE: Frigidaire Gallery Series range/oven showing
Service tech came the next morning (Nov.26th). The sensor tested out OK. He said that the control board needs to be replaced. Unfortunately there wasn't one available for this model - he had to order it, and he'll be back next week. The good news is that my lovely wife had purchased an extended warranty - so it appears that all parts and labor is covered. We all ended up eating out for the Thanksgiving holiday, and no- the restaurant bill wasn't covered by the warranty. I'll keep you posted on the control board replacement.
Posted on Nov 28, 2008
  • 3092 Answers
SOURCE: F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Posted on Jan 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire Classic Range, Model # FEF366CCB, F1 error
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^%$RF
Posted on Oct 01, 2010
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Replaced desplay board and nothing worked replaced right and left relay boards and clock works nothing else flashes f1 f1 checked wiring harnness with ohm meter ok dont know what else to try
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 27, 2010 | Jenn-Air Electric Double Oven
STOVE STUCK ON SELF CLEANING CYCLE
Try pushing all buttons several times each to unstick a stuck panel button. If that does not work the ERC clock control will have to be replaced.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Dec 12, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 19, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire electrolux gallery series
stoveboy,
I know you probably have the problem fixed by now, but I had the same problem with my frigidaire range just the other day. Loud popping sound, range/clock controls do not work. Stovetop still works great.
I took the back off the stove and got to the circuit board. Unplug the connector and the five spade connector wires. Once you do that, remove the 4 screws holding the entire assembly in place. The circuit board(s) are held in the housing with retaining clips on the housing. Use a small screwdriver or similar to pull back on each clip to pry each side of the board out. Once the board(s) are free, look in between the two circuit boards and you will see the problem. The larger, 20 amp relay is the culprit. It blew traces off of both boards making it almost impossible to repair. Without having a schematic to go by, I went ahead and decided to just replace w/ new boards as opposed to trying to solder the traces. I have not checked on prices, but brief web searches didn't return any results. The board part # is SF5301-S7509-N
Apr 14, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
110 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
