Back to:
Tags:
SanDisk 2GB Cruzer Micro USB Flash Drive  Hard Drive
Forgot my password on my sandisk u3 cruzer 4.0gb (by 13 users)
posted by tonymann on Mar 10, 2007
i forgot my password on my sandisk u3 cruzer 4.0gb is there anyway i can access my file. The only option i have it seems is to reset my password and lose all my exiting saved files is there anyway around this please help thank you
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
12 Other Users Have The Same Problem
Comment by Guest, posted on Sep 06, 2008
Comment by cward12, posted on Jul 24, 2008
I have a 8gb Drive and i need Help with the same Problem
Comment by Guest, posted on Jul 07, 2008
I cant log into my usb, I dont remember my password and need so many important documents from it.. WHAT DO I DO? I have the 4GB cruzer
Comment by Guest, posted on Jul 01, 2008
My sister forgot her password and she dont want all her pictures to be gone.
what should we do?
Comment by Xzen, posted on Mar 05, 2008
same problem on the 2GB version i dont know my password, please help i have GCSE work on there, really important
Best Solution
posted on Jul 25, 2008
Helpful (85)
anaesarora
Rank:Guru Guru
Rating: 88%, 35 votes
hello
i am into data recovery
i shall first do semi data recovery
try to see if my password is on the recovered data.
use it to log in
or else if password not there i shall do a full data recovery.
back up data then reset the drive.. load the data back again
and give it back to you.
0-9-3-3-2-1-0-1-7-1-7
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on forgot my password on my sandisk u3 cruzer 4.0gb:
I don't want to Accept this solution
Solution #2
posted on May 08, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
RescuePro will help you all!
Thank You!
Solution #3
posted on Mar 12, 2007
Helpful (85)
shaky120
Rank:Wiz Wiz
Rating: 85%, 280 votes
according to the website, it is not possible to access the data without the password,
only way i can think of is maybe hack into the device, but i would need the device to try.
All the best
John
Thank You!
Solution #4
posted on May 07, 2007
Thanks for Trying (70)
markpeper
Rating: 75%, 12 votes
I assume that you tired the 'secret question' that will provide a hint as to what your password was -- it is the hint that you set up when you first chose your password.
Thank You!
Solution #5
posted on Jul 04, 2007
shisken
Rating: 70%, 1 votes
You simply cannot access your files. To reuse the drive, you must format the second larger disk.
Thank You!
Solution #6
posted on Sep 15, 2008
Not Rated (0)
s_orosco3
Rating: 0%, 0 votes
I can not save anything to my sandisk when I save from powerpoint. It says I have to enter a product key code. Help
Thank You!
Solution #7
posted on Sep 14, 2008
Not Rated (0)
node_11
Rating: 0%, 0 votes
Thank You!
Solution #8
posted on Apr 01, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i have same problem too
4 gb
Thank You!
Can you Help with these Hard Drives problems?
SanDisk 2GB Cruzer Micro USB Flash Drive...
I need drivers for my compaq presario cq50-102 la, i can't...
My Cruzer 2 GB won;t show up on teh desktop, light comes...
I copied pics from my daughter's computer on to my SanDisk...
My parents philips tv is stuck on the menu screen. I...
i forgot my password to cruzer micro 8gb
12 Other Users Have The Same Problem - Continued
Comment by cham2040, posted on Mar 05, 2008
Please describe the specifics of your problem below. We'll add
your post as a comment to tonymann's forgot my password on my sandisk u3 cruzer 4.0gb problem, and notify you when a new solution is offered.
Comment by snowbill, posted on Mar 03, 2008
I have the same problem as everyone else. I have very important documents I need to retrieve and for the life of me cant remember my password. I have too many passwords!!! Any solutions besides loosing all my info?
Comment by mopey 123, posted on Feb 29, 2008
I didn't forget my password but I still have difficulty logging in to see my files. I was able to log in once and the second time I tried, I was denied access. What can I do to prevent from losing all my files?
Please post the solution if you have one!! Thanks
Comment by Guest, posted on Feb 21, 2008
forgot password
Comment by elGallo, posted on Feb 12, 2008
same here! forgot My password.......Need help
Comment by Guest, posted on Jan 31, 2008
some one lock my sandisk memory card on my phone how can i unlock it
Comment by Guest, posted on Dec 10, 2007
what do i frekin use to figure out my forgotten password san disk cruzer 1.0
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
