How we can add extension in file type of open file dialod box
How add file type
    President:
  • 373 Answers
If you want to change the extension of an existing file type, then open any window, goto->tools-> folder options->view-> uncheck the option that says "hide extensions for known file types". Once you do that you'll get the filename with extension.You can necessarily change it accordingly.
Posted on Dec 13, 2008
Instructions delete
This describes what Deal4me is:
Deal4me adware how to remove it
First, you can uninstall it through Start > Control Panel > Add/Remove Programs (Renamed Programs and Features in Windows 7)
You will also want to download, install, and run an Anti-Malware utility, such as the free version of Malwarebytes from:
Malwarebytes Anti Malware Pro
Aug 31, 2014 | Computers & Internet
Tip
Unable to run executable files (. Exe) on windows platform
It may happen that only executable files aren’t eager open properly: either you have the dialog box "Open With", it opens with notepad or another program.
This problem may be due to a error made on your PC. If this is not the case, then it is necessarily a virus, follow this tip to disinfect your PC.
To correct the problem, follow these steps:
First Solution This solution is valid for XP and 2000 versions.
  • Go to Control Panel and then Folder Options.
  • Select the File Type tab and then click New
  • Type in EXE file extension and click OK
  • The EXE extension is automatically selected, then click Restore
  • Close the dialog box
Second solution This solution works for all versions of Windows
  • Click on Start> All Programs> Accessories> Notepad
  • Select the text below> copy and paste it into Notepad
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\exefile]
"EditFlags"=hex:d8,07,00,00
@="Application"
[HKEY_CLASSES_ROOT\exefile\shell]
[HKEY_CLASSES_ROOT\exefile\shell\open]
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\exefile\shell\open\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shellex]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\{86F19A00-42A0-1069-A2E9-08002B30¬309D}]
[HKEY_CLASSES_ROOT\exefile\DefaultIcon]
@="%1"
  • Then click on File> Save As ...
  • Select All files Type
  • Give a name for the file and add the. Reg
  • Click on Save
  • Close the notebook and then right-click the file. REG> Merge
  • Click YES and OK
on Jun 15, 2010 | Computers & Internet
I'm unable to rename any file in win XP,a message appears "If you change a file name extension,the file may become unusable" Plz help
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Mar 13, 2011 | Microsoft Windows XP Professional
How to crupted all file of any coumputer
If you want to delete all your files off your hard disk then just format the hard drive.
Feb 10, 2011 | Computers & Internet
Window media player cant open my file
You probably need codec pack for that, and update of media player is not bad idea either.Go to free-codec.com and get what you need.
Nov 16, 2010 | Acer Computers & Internet
Cannot open P3 projects with logos embedded in footer ( logo files are windows metafiles). P3 hangs up on opening layout; (then when closing P3, error message paraphrased "ntvdm.exe file is non-responsive"...
1. Go to My Computer
2. Go to Tools
3. Folder Options
4. File Types Tab
5. Find the file type "Primavera Draw" with the "PMT" extension
6. Delete this file type
7. Click on the "New" button to create a new file type
8. Enter "PMT" for the file extension and click OK
9. With the "PMT" file type selected, click on the "Advanced" button
10. Enter "Primavera Draw" in the box next to the "Change Icon" button
11. Click on the "Change Icon" button
12. Click on the "Browse" button and navigate to C:\P3WIN\P3PROGS\PRMDRAW.EXE
13. Select one of the two icons (I like the color one) and click "OK"
14. Click on the "New" button next to the "Actions" list
15. Type "open" in the box under "Action"
16. Type "C:\P3WIN\P3PROGS\PRMDRAW.EXE" in the box under "Application used to perform action"
17. Click "OK"
18. Click "OK" again
19. Click "Close"
20. Close "My Computer"
Sep 24, 2009 | Primavera Project Planner P3 (PRIMAVERAP3)...
Hi I upgraded my blue ray player's firmware, and after I did I can't get access to my Linksys ip address. When I type in the default 192.168.1.1, I get an error message from Explorer. Can sommone help...
Warning Enable dynamic content when you really want to use it. By default, IIS disables dynamic content for security reasons.
To permit IIS to serve dynamic content, the administrator must unlock this content in the Web service extensions node in IIS Manager. To do this, the administrator must either enable a pre-existing Web service extension or add a new Web service extension.
Enable a Pre-existing Web Service Extension in IIS 6.0
To permit IIS to serve content that requires a specific ISAPI or CGI extension that is already listed in the Web service extensions list, follow these steps:
  1. Open IIS Manager, expand the master server node (that is, the Servername node), and then select the Web service extensions node.
  2. In the right pane of IIS Manager, right-click the extension that you want to enable. In this example, this is Active Server Pages.
  3. Click to select the Allow check box.
Add a New Web Service Extension to IIS 6.0
To permit IIS to serve content that requires a specific ISAPI or CGI extension that is not already listed in the Web service extensions list, follow these steps:
  1. Open IIS Manager, expand the master server node, and then select the Web service extensions node.
  2. In the right pane of the IIS Manager, click Add a new Web service extension under Tasks.
  3. In the Extension name box, type a friendly name for the extension that you want to add (for example, FrontPage Server Extensions).
  4. In the Required files box, click Add, and then select the path and the name of the file that will handle requests for the specific extension. After you select the path and the file name, click OK.
  5. If the extension must be enabled immediately, click to select the Set extension status to allowed check box.
  6. Click OK to save your changes.
Additional steps for Common Gateway Interface (CGI) applications
For CGI applications, you must also follow these steps:
  1. Right-click Default Web Site or the Web site that you want, and then click Properties.
  2. On the Home Directory tab, click Scripts and Executables in the Execute Permissions list.
  3. Make sure that the Everyone group has the following NTFS file system permissions on the C:\InetPub\wwwroot folder or on the folder that has the Web content for the site that you want:
    • Read & Execute
    • List Folder Contents
    • Read
  4. Right-click Default Web Site or the Web site that you want, and then click Properties.
  5. On the Home Directory tab, make sure that DefaultAppPool is selecting in the Application pool box. If another application pool is selected, follow these steps in IIS Manager:
    1. Expand Application Pools, right-click the application pool that you want, and then click Properties.
    2. On the Identity tab, make sure that one of the following conditions is true:
      • The Network Service account is selected.
      • The account that is selected is a member of the IIS_WPG group.
Jun 30, 2009 | Linksys Wireless-G WRT54GS Router...
Rename file extensions
To display file name extensionsDepending on your settings, the file name extensions of your files may not be visible. To display the file name extensions of your files if they are not visible, follow these steps:
  1. Open My Computer or Windows Explorer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab.
  4. In the Advanced settings box, click to clear the Hide extensions for known file types check box.
  5. Click OK.
Hope This Helps, Please Rate My Response! Thanks! Prem
Feb 19, 2009 | Microsoft Windows XP Professional With...
My Windows Explorer does not show extentions
By default, file extensions for known file types are hidden in Windows XP. However, you can change this setting so that file extensions are shown for files in a certain folder or for all files on your hard disk.
To show file extensions, first open any folder on your hard drive, such as "My Computer" or "My Documents." Then select "Folder Options..." from the Tools menu as shown below.
545a526.gif When the Folder Options window opens, click the View tab. This will show the file and folder view settings.
95b32b0.gif One of the options under Advanced settings is "Hide extensions for known file types." If this option is checked, uncheck the checkbox and click Apply or OK. This setting is system wide, so unchecking this box will make file extensions appear in all folders.
If you decide to hide file extensions at a later time, you can check the box again and click OK to revert back to the previous settings.
Jul 16, 2008 | Computers & Internet
TRIED TO BURN A CD WITH ANOTHER LAPTOP. MINE WONT READ THE PICTURE FILE, BUT WILL READ ANOTHER TYPE FILE. THE LAPTOP WE USED PUT THE FILES ON THE DISK. WE READ IT WITH ANOTHER COMPUTER. I ALSO HAVE MORE...
maybe your computer don't recognize the file extensions of your files...
if you have a ms office picture viewer'
open it,
tools,
file types then add the file extensions to be able to read them...
if you have another software,
try to find the file types it can read and add the others...
ex..bmp, jpeg,jpg,gif,png,etc...
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
