Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
My laptop doesn't detect the external hard drive
I recently purchased a 320GB freeagent go. When I plug it into a USB port on my laptop (HPpavillion dv 1000), it is not detected by the computer. The drive just sits and blinks (the light fades up and down). I tried plugging it into a newer laptop (Lenovo T61 with Windows Vista) and I had the same problem. Is this a power issue?
  • Anonymous Apr 23, 2009
    Exactly the same problem.
  • 3,051 Answers
Hi there
hey if you are not getting it to recognizing the drive on system startup use your set up disk if you have it if not go to device manager and scan for hardware change and see if it can be found there if not try going into the bios and ensure that the usb ports are enabled and that the plug and play is enabled also you also need to ensure that the device is compatable with your pc i would check with the manufacture of the computer best regards mike
Posted on Feb 16, 2009
  • killer917 Dec 25, 2010
    my freeagent 750GB did work untill i formated it, now my laptop wont detect it. can some one help please. a orange light just fades slowley ...
Seagate-free-agent-external-drive 320gb doesn`t show up
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 31, 2011 | Seagate FreeAgent Pro Desktop - 320GB -...
I have a seagate externial hard drive it worked fine went to use next day and it wont power up....any way of gettign my stuff off of it
First thing to do is try a USB port on the back of your computer. Also try another computer to see if it is just a bad port.
Mar 19, 2011 | Seagate FreeAgent Pro Desktop - 320GB -...
Freeagent Go not recognized as an identifable USB device.
I plugged mine's directly through the back of my computer instead of the hub in the front and it's working fine.
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I own a 320GB seagate freeagent hard disk and accidentally unplugged it from my laptop a few days back. It gives a beeping sound whenever I try plugging it into a laptop and I've tried 3 laptops, all gave...
Connect the 320GB HDD before switching ON the laptop and try to repair using scandisk option to repair the drive. Also use chkdsk /f option in command line mode.
Revert back for more assistance.
Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
My usb port is broken
Then you need to get it repaired there is no alternative.Contact you company if ur comp is still under warranty else you can contact any comp repair shop.
Nov 28, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Jan 01, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
845 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
